fuse block location 55 caddy
Discussion in 'The Hokey Ass Message Board' started by rzylonely, May 20, 2013.
  1. rzylonely
    rzylonely
    from moose jaw
    hello
    i need help--were is the fuse block for a 55 caddy...i have NO signal lights..need to locate the fuses/flasher unit..please..
  2. 24riverview
    24riverview
    This is what it looked like in a 55 ElDorado before I rewired it few years back. If I remember correctly this is on the firewall just above the transmission hump, I would ***ume yours would be similar.
  3. Frank the Crank
    Frank the Crank
    from So Cal
    There is a main circuit breaker for the ash tray, fog, head, map, instrument, parking and stop lights that is part of the light switch. The fuse block is located on the cowl under the instrument panel just left of the center. If you need the factory fuse sizes let me know.
