Technical Fuse Box ACC Question
Discussion in 'The Hokey Ass Message Board' started by ZZ Top Chop, Mar 6, 2022.
  1. ZZ Top Chop
    ZZ Top Chop
    Screenshot_20220317-155932_Gallery.jpg Screenshot_20220317-155941_Gallery.jpg All finished. I have more room to add a additional accessory if I ever need it. Didn't occur to me until I was installing that I was counting the amps for the fan when I should have just been adding the amps of the sensor. Moving the airbags to a switch was the right call, now when I turn the key I don't have to fight the compressor draw at start up.
    pprather and Woogeroo like this.
  2. pprather
    pprather
    Have all the accessory loads been moved off the ignition switch?
  3. 325w
    325w
    Bought a car that was a new body frame and used hot rod motor. All decent new parts. Didn’t even look at the wiring. Get home and look under the dash. My goodness what a mess. Wires twisted together then shrink tubed. Left a large knot in the heat shrink. I cut some out and crimped them. Later my son did some more he found. If you don’t need a lot of circuits I’d use Rebel harness.
    ZZ Top Chop likes this.
  4. ZZ Top Chop
    ZZ Top Chop
    Yes, sir.
    pprather likes this.
