Customs fusible link
Discussion in 'The Hokey Ass Message Board' started by bangngears, Jan 21, 2017.
  1. bangngears
    bangngears
    from ofallon mo
    Where is the fusible link located for mid 60 s chevy. Looked along the fire wall bundle, so next will be from battery back. Info may save time and trouble. Tried inter net, no help
  2. Leakie
    Leakie
    Did you check by the starter?
  3. Twin Stick
    Twin Stick
  4. skip57
    skip57
    from md.
    Do you have a small wire at the batt. (68) or from starter positive post the body.
  5. squirrel
    they don't have one.
    bobss396, 302GMC and RICH B like this.
  6. Leakie
    Leakie
    Didn't Chevrolet start using them in 65?
  7. What year Chevy are you talking about here?
  8. bangngears
    bangngears
    from ofallon mo
    1967 but kinda off topic because of year
  9. Check your P.M.
  10. bangngears
    bangngears
    from ofallon mo
    Ok, its a biscayne. Jumpered the ignition and started it with the old screwdriver trick across the starter, got it back in the garage. havent untaped wires from battery to starter. No power anywhere, so has to be a link in there somewhere
  11. squirrel
    What does the horn relay look like? they were commonly used as a power junction in that era...if it has a big screw terminal on it with a few big red wires, see if there is power there.
  12. bobss396
    bobss396
    I believe the fusible links came in with electronic ignition. I recall the GM cars having this heavy purple wire that would often bite the dust if it was severely overloaded. IIRC it went from the ignition switch "start" down to the "s" terminal on the starter.
  13. Engine man
    Engine man
    from Wisconsin
    Here's a wiring diagram found with a quick web search. There's one between the battery positive and a terminal near the battery. I think it also shows a fuse in a black wire but it's hard to read.
    When GM started putting the extra wire on the battery cable, and the cable end failed, many people used the bolt on cable end. I've seen the smaller wire corrode in those connections.
  14. squirrel
    wonder what year that diagram is? It doesn't say. 1966 cars did not have the fusible link.
  15. skip57
    skip57
    from md.
    MY 68 NOVA had the same problem. If IRC the small wire ran a cross the core support. That is where I found the same problem. I know the 68 Nova wiring looked some what like the one ENGINE MAN put up.
  16. bangngears
    bangngears
    from ofallon mo
    Bobg1951chevy told me what to look for and viola its fixed. Wire from behind r/f headlight pulled out of the crimp apparently when the battery moved , wasnt locked down . It will be now
    Leakie and bobg1951chevy like this.
