Technical FWIW
Discussion in 'The Hokey Ass Message Board' started by Groucho, Jul 21, 2015.
  1. This happened a few weeks ago, but I just now thought maybe I should share. Or, most of you already know this(?) While diagnosing the charging system on my 40......still 6V and a generator I was getting very false readings on my digital volt meter. Trying that meter on another car showed it was working fine. I had to dust off an older*****og meter for accurate readings. Like I said, most may already know this, but since I rarely get 6V stuff in my shop........
  2. Bruce Lancaster
    Bruce Lancaster
    The explanation I have heard is that a digital meter tries to follow the voltage, which is controlled by vibrating points that produce spikes averaged in with nothingness...the gauge can't possibly follow that mess, and so slides into a psychotic break.
    The*****og meter placidly scans continually over spike and over open and accepts the average that the rig is putting out, just like your battery does...
  3. My dad wouldn't use anything but*****og, he said that electronics were effected by external noise too much to be accurate on anything that was not filtered. I would think that an old 6V system would be really noisy.
    Good info I will keep it in mind.
  4. FrozenMerc
    FrozenMerc
    It would be interesting to put the 6V gennie output on a oscilloscope and see exactly what the wave form looks like. I run into similar problems with the day job in trying to instrument 2 stroke snowmobiles with battery-less EFI systems, talk about noisy voltage signals. The battery acts like a huge capacitor and absorbs a lot of the noise and spikes.
  5. OT I know but when I was still working as an operating engineer I had an ultra modern centrifugal chiller. We had to install filters because the incoming electricity to our building was so dirty (noisy) that the electronics could not function.
  6. Bruce Lancaster
    Bruce Lancaster
    The old style regulators actually regulated by noise, it would seem!
  7. falcongeorge
    falcongeorge
    from BC
    well, theres something happening here, but what it is aint exactly clear.
  8. HOTRODPRIMER
    HOTRODPRIMER
    Buffalo Springfield? :D HRP
  9. falcongeorge
    falcongeorge
    from BC
    I was just surprised it took till post #7...:D
