G.M. TBI ?
Discussion in 'The Hokey Ass Message Board' started by W Vaughan, Jun 15, 2004.
  1. W Vaughan
    W Vaughan
    from Benton Ms.
    Anyone have a real good wiring diagram for 88-90 G.M. TBI. I'm trying to retrofit into an earlier model car using the factory harness. I know painless makes a harness but I can't afford it. The wiring diagram I have has some things screwed up. I've figured pretty much everything out except the power to the ECM.
    Thanks
    Will Vaughan
  2. W Vaughan
    W Vaughan
    from Benton Ms.
    Come on now I know someone here has tried this.
    Thanks
    Will Vaughan
  3. DrJ
    DrJ
    V6 or V8?
    I have factory manuals on the 88 Astro Van 4.3L V6.
  4. Paul
    Paul
    Editor
    I have a shop manual for the '90 454SS truck,
    I can look if that'll help
    Paul
  5. W Vaughan
    W Vaughan
    from Benton Ms.
    It's a 5.7 V8.
    Thanks
    Will Vaughan
  6. Paul
    Paul
    Editor
    [ QUOTE ]
    It's a 5.7 V8.
    [/ QUOTE ]
    is that like a 7.4?
  7. W Vaughan
    W Vaughan
    from Benton Ms.
    I think they were about the same. The diagram I have is showing two B3 terminals in the Ecm Conector and that is not right.
    Thanks
    Will Vaughan
  8. Paul
    Paul
    Editor
    of course now I can't find the stinkin' book but I did find a couple basic Chiltons,
    it also appears to show two B3 connections at the Engine Control Module..?
  9. W Vaughan
    W Vaughan
    from Benton Ms.
    Thats the same diagram I have. It shows two B3 connections, but there is only one. I think one of them is supposed to be a B2. What I'm trying to do is wire the harness to stand alone from the rest of the factory harness. I have all the sensors and the injectors figured out but I need to figure out the power to the ECM.
    Thanks
    Will Vaughan
  10. grtpmkn
    grtpmkn
    majestic wiener
    from Kansas
    Ok i will help I put a TBI in my 41using a stock harness, give me a couple days and i will look and tell you what goes where on the wires, whats your email.?
    Matt
