Anyone know what c6 I can use? I found one all the guy knows is its a 79. I know it needs to be a flat top but if I remember correctly there is 2 different flat tops?....any way to decode the numbers on the trans or anything like that? The pic is the actual trans I'm looking at
Most common spot for an FE compatible C6 is in a '70 to '76 2wd F150 / 250's with 360's or 390's. The 1979 date of the 1st transmission should have been a big clue since Ford stopped making FE's in '76.
The last year a FE was used in cars was 1970. As noted above, the FE hung around in trucks until '76 but most were the short tailshaft versions until '73 when Ford finally got away from the two-piece driveshaft on the longbed trucks.
Yep, it does. The short tailshaft versions don't have a slip yoke on the output shaft; the yoke is bolted to the output shaft (like a rearend). The slip yoke was in the rear half of the two-piece driveshaft. I suppose you could have a custom driveshaft built with a slip yoke in it (Jaguar did this with the GM TH400 they used behind their V12), but it would probably be easier to convert a short tailshaft version to a long tailshaft with a donor C6 from another application. This will require complete disassembly of the trans though.... Ford used a one piece driveshaft in the earlier shortbed pickups with the long tailshaft, but not many of those were sold with FE motors.
