Galaxie Dies when decelerating
Discussion in 'The Hokey Ass Message Board' started by dorksrock, Jun 25, 2011.
  1. dorksrock
    dorksrock
    I have gotten my '63 Galaxie running, and the brakes working, the original 352 running pretty good, etc after sitting since '78. But I have a problem, When im braking or decelerating, she dies, and sometimes wont stay running after its been run for a while unless you keep your foot on the gas, and sometimes even then wont. I never have a problem when the engine is cold, just sometimes after its been up to temp for a while. I did a search, and found someone with a similar problem that was related to the float level. Do you guys think that this is my problem? Also, I know that the original dashpot doest work any more, could this be my issue? I wanna try to get this issue fixed so I can cruise in it on my birthday. (This Monday, send me your vintage goodies and stuff. You didn't want it anyways)
    Heres a pic for ya guys!
  2. Might be a fuel pump of clogged fuel filter.
  3. dorksrock
    dorksrock
    fuel filter is on my to do list tomorrow, seeing that I have never replaced it. :eek: good chance its crudded up.
  4. float level sounds suspect.
  5. Bluto
    Bluto
    I think it's a Ford safety feature! :D
  6. KULTULZ
    KULTULZ
    If an automatic, it has to have a dashpot, functional and adjusted properly. It also sounds like the carb is not adjusted correctly, including base idle.
  7. oj
    oj
    Just rebuild the carb, it has been sitting since the 70;s and has crud inside it, the idle circuit likely stopped up or restricted.
    I'm not certain what you mean by dashpot - the high idle solenoid when the air conditioning is on?
    No the problem isn't float level - it is the idle circuit. The idle circuit is always functioning, it is what provides fuel when you lift your foot off the throttle like slowing down etc.
  8. csimonds
    csimonds
    I had a 67 Galaxie with the 390fe that was doing the same thing. I had to take the time and adjust the carb properly, after that no more stalling at stop lights. Try that and see how you make out.
    Chuck
  9. plym_46
    plym_46
    from central NY
    I remember those as being very particular about float level and operation. Double check that system and ***ure it is up to spec and workig properly.
  10. dorksrock
    dorksrock
    It is and automatic car, and I did rebuild the carb about a month ago. I gotta dig through my pile of stuff and find my vacuum gauge and get that carb adjusted, and pop off the top of the carb and see if I set my float level right. As far as a dashpot, I am having trouble finding one, None of the parts stores even know what one is.
  11. rougebeats
    rougebeats
    You need the dashpot. Its what your carb linkage "rests" on during deceleration and I believe is vaccuum controlled. If the plunger on the dashpot is stiff or doesnt move etc then it will keep doing what your talking about. I had a 64 olds with a 394 that did that til I replaced mine. I didnt have the trouble you are having finding one though. Put up a wanted ad in the cl***ifieds on here. Im sure there is someone on here that can help you out. Good luck!
  12. Mr48chev
    That is what I was thinking, The dashpot keeps the throttle plate from closing too quickly and starving the engine when it is slowing down.
    Float level could be a tad low too but it does need the dashpot.
  13. rougebeats
    rougebeats
    Another thought is that the dashpot from a 390 (or similar) may interchange, and be used on your carb as well. Worth looking into.
  14. dorksrock
    dorksrock
  15. The dashpot keeps the engine from stalling on deceleration.
  16. von zipper
    von zipper
    Sounds like it to me!
  17. KULTULZ
    KULTULZ
  18. dorksrock
    dorksrock
    Sounds like what I need to solve my issue. I know the engine is tired, but If I can get one good summer of cruising outta it I will be thrilled! Time to get a dashpot!
