Hot Rods Gambino kustoms san jose speed and chrome presents fatman fabs wishbone giveaway
Discussion in 'The Hokey Ass Message Board' started by Gambino_Kustoms, Feb 6, 2010.
  1. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    post a pic and i will
  2. n.z.rodder
    n.z.rodder
    Ok, I'll have a bit of this, please.
    Just started collecting parts
    '40 pick-up, Slightly channeled, fenderless with hood and std grille. '59 283 & glide. Tube frame similar to pic 3 only with a kick up in the front as well to fit a dropped I beam. Not sure if I'm going with wires or solids and caps. Gloss paint.
    Postage to here (N.Z.) is no problem thanks.
  3. dieselc
    dieselc
    from ohio
    Alex you are one hell of a guy, how long does it take to sort through all these posts?
  4. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    not that long just lately weve got somuch going on this is a destraction
  5. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    need a pic of some thing a rendering dosnt work
    sorry and thanxs
    pic please
    any pic
    the axel the tires the body the motor
  6. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    thanxs man rules are rules:D you made it !
    chevys rule yer in for 2
    down for 2 good luck
    you made the cut
    got ya for 1
  7. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    you made it and these would be the corect lenghth
    yes they would you get 2
    yes sir your on the list
    great car you get 2
    no your not late you got 2
    yer in the ring fer 2 *****in car
    good luck your on the list
    you made it we leave no one be hind esp our dead
    its a start good luck your on the list
    *****in car you made it
    good luck your on for 1
    yes sir you made it
    need a pic
  8. Griffdaddy4
    Griffdaddy4
    from Albany,Oh.
    This project is NEEDY! It is a '29 Ford Model A roadster with a SBC 305 and powerglide and is slow in progress due to the weather conditions in Ohio now. Griffdaddy4
  9. HOTRODPRIMER
    HOTRODPRIMER
    I would like to throw my car in the mix,,,the ol' sedan has been on the road a long time and when it was built it was considered a traditional style before it was really popular.
    Flathead powered,3-speed ****** no frills car.
    One of the things that has bothered me for the last few years is the 4 bar front,,,not that it's bad but it just doesn't have the right vibe.
    Bones would make a big visual improvement.HRP
    mymoredoor
  10. dieselc
    dieselc
    from ohio
    I can imagine it is a handful with trying to run a shop and keep up with this.
  11. Heres my entry for those bad *** bones!!
  12. blue collar guy
    blue collar guy
    those hub caps make her ***s look small
  13. hupster
    hupster
    from california
    Here's my entry. My 31 coupe. The gold Cadillac motor is a 59 390. The Edmunds 2 X 2 that sits awkwardly atop the motor was born into a Studebaker family, but will undergo a religious conversion and become a good Cadillac. Wheels of choice are 16" Kelseys. I plan to give the top a 4" chop and place the body on the 32 frame from our friend Duane at Kiwi Konnection. Please note, there are no front end parts on the frame. That's because I have none. Those new Fatman wishbones would be a great start for the front end. Please add me to the list.
    Thanks, Gary
  14. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    man alot of nice stuff in this post
  15. HotRodHighley
    HotRodHighley
    from cincy, oh
    i would like to have them on my coupe.
  16. lockwoodkustoms
    lockwoodkustoms
    This is our entry for the bones.
  17. Thorkle Rod
    Thorkle Rod
    I could really use them best on My 36 Fruck
  18. Corn Fed
    Corn Fed
    How about a '33 Fordor? Will be a mid 60's theme with a mild chop, blue body, silver/blue metal flake fenders, and a diamond tuff interior. Twin blue S/W gauges. 327-4spd. '57 Ford rear w/P&J ladder bars using a stock spring. Chrome reverse rims with pinner whites. I need those now because I'm currently setting up the front suspension.
  19. Iceberg460
    Iceberg460
    Still collecting parts for mine. With the exception of the BBF 460, auto and 9" (parts I already have) it will be a traditional build...
  20. Verbal Kint
    Verbal Kint
    from Washington
    I would like them for my dads 32 - 34 "pile of parts" pickup. We will have the frame in the jig by mid May. Full fendered, bobbed bed, 292 Y-block, C4, etc...
    Thanks.
  21. grits
    grits
    I'll go and drop my name in the hat also, great looking bones. Thanks guys.
      417.8 KB
      116 KB
      105.8 KB
  22. hotcargo
    hotcargo
    [​IMG][/url][/IMG]
    The Fatmans bones would look good on my little project , stick me down for the Mighty Give a Way
    cheers Steve in Oz
  23. 1930roadster
    1930roadster
    I'm in, those are killer and will fit the build on my 29 A Roadster, Flathead, steel wheels, making a holey frame and then some more holes! but then again, i never win anything...
  24. dv8
    dv8
    Here's mine...1926 Dodge coupe...cut down roof/door tops. It's shortened for a Model A frame. I'm using a 1953 Dodge Red Ram Hemi. I'm using a Ford front end. I think it has a cool jalopy vibe...
    Thanks!!!
  25. 510madmav
    510madmav
    I'm building a 28-29 Model A roadster from scratch. Dont have too many parts now, These bones would certainly be a cool addition to my pile o parts to be put on my roadster! And im next door in San lorenzo CA.
    Heres the only pic i could find right now. I now have a cowl, and some doors.
    Thanks guys!
  26. Garry Carter
    Garry Carter
    This is one of my driver's at present; but I'm gettin' ready to blow it apart and change a bunch of things on the re-build. Them bones would be a killer addition!!!
  27. BCCHOPIT
    BCCHOPIT
    How did you know I wont to split my wish bones this winter...
    I have some old rusty ones behind my shed But I like yours a lot better.
    sorry about the size
    The new bones would look nice with the new wheels
    Thanks Bill
  28. rc32tx
    rc32tx
    Count me in Alex, as I could sure use that mojo! 32 pickup w/3 inch chop on deuce rails, 283 w/three Holleys, 4 speed muncie, 9 inch and Firestone WW.[​IMG][​IMG]
  29. rc32tx
    rc32tx
    the pics!
  30. bbanks12
    bbanks12
    pics, my existing bones are pretty rough from rust pitting, but so was the whole car lol
