Technical Garage Floor Protection
Discussion in 'The Hokey Ass Message Board' started by spillaneswillys, Sep 25, 2023.
  1. I just put a finish on my garage floor and I have three hot rods that all leak something. What floor mats have you guys found that protect the floor underneath the best? Thanks
  2. squirrel
    As long as it's not brake fluid, the spills don't hurt the finish on the floor in my new place, so I just let them drip, and wipe up occasionally. But I also try to fix the leaks as much as possible, which isn't 100%.
  3. Bandit Billy
    Bandit Billy
    Summit offers an oil absorbent mat that I purchased to go under my drippy VW dune buggy when it is in the trailer. Cheap, looks nice, works.
  4. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    I just do cheap ole cardboard boxes broke down. When it gets nasty looking, change it out to a new box.
  5. Kevin Ardinger
    Kevin Ardinger
    I use a Kotex pad on my torque converter shield held on with magnets. Nothing hits the floor. It’s not that bad of a leak so I don’t need a maxi pad, but I do need some thing a little more than a ***** liner. Too lazy to pull it back out.
  6. pirate
    pirate
    from Alabama
    If you go to Walmart or any of the big box stores like Home Depot or Lowe’s and probably many other places pick up a shoe or boot tray. Some can be had for under $5.00. They are usually 15” x 30” or so and have a 1” lip or so. Put them under the leak wipe them out with paper towel.
    https://www.walmart.com/browse/home/boot-trays/4044_133012_110892_4768882_3609016
    Also very handy on you workbench for dis***embly of items with liquids or small part IMG_2349.jpeg
  7. SS327
    SS327
    That’s funny when I used to do police towing back in the early 80s that’s what we used! Tampons for holes!
  8. jaracer
    jaracer
  9. 31Apickup
    31Apickup
    I just use old baking sheets.
  10. Bandit Billy
    Bandit Billy
    Perhaps "lite days".
  11. Every so often my wife updates the bathroom throw rugs and the front and back entry rugs. The old ones cycle out to the garage for a couple of years before they go in the dumpster. I've got a big 8 x 12 under my daily right now that used to be on the back deck.
  12. stanlow69
    stanlow69
    IMG_1114.jpeg IMG_1113.jpeg Go to the parts store and buy a drip pan. They work good for working on project on a worktable too. Keeps all the fluids contained. I know a guy whose house burned to the ground because his gas tank was leaking (Unaware this was going on) onto the cardboard under his cars. The battery charger sparked, and the rest is history.
    Cosmo49 likes this.
  13. 1934woodie ply
    1934woodie ply
    Saw dust will ,take oil out of concrete
  14. JD Miller
    JD Miller
    cardboard, s****s of plywood , carpet s****s, plastic lids from your wife's tupperware cloths storage
    anthony myrick likes this.
  15. Bandit Billy
    Bandit Billy
    Cool Idea...(someone cut me in on the profits) a round "logo" looking oil mat under the car. Chevy, Ford, Mopar, etc. Oil absorbent, washable. Shark Tank!
  16. I was looking at the mats that are approx. 5 x 20 that roll out. They are somewhat expensive and was trying to see if anyone has used them. To find if they work well?
  17. Jmountainjr
    Jmountainjr
    For drip pans, parts trays, etc. I go to the Walmart cooking section. Large selection of various sized aluminium baking sheets. I have two smaller ones under the bed of my lathe to speed up cleanup. Loaf pans for storage. The aluminum wears and cleans up better than plastic.
    williebill and sidevalve8ba like this.
  18. 05snopro440
    05snopro440
  19. 57JoeFoMoPar
    57JoeFoMoPar
    IMHO there's nothing better for a garage floor than a real epoxy. I used a 100% solids coating I got from ArmorPoxy, and it has held up unbelievably well for the past 7 years. Drip pans and cooking sheets are fine to catch the odd leak, but the floor always gets something on it. I just mop mine up and keep it moving.
    73RR likes this.
  20. chop&drop
    chop&drop
    A piece of indoor/outdoor carpet with a “rubber” backing works for me. I got dark gray and you can’t even see where it drips. Cheap at Home Depot
  21. '29 Gizmo
    '29 Gizmo
    from UK
  22. 1971BB427
    1971BB427
    from Oregon
    I also have a couple oil drip pans that measure 25" x 36" that I use for any temporary leaks. Just until I can address the issue. But I also put them down under catch pans when draining fluids, as it seems like I always end up with some oil not landing in my catch pan when changing oil and filter.
    pirate likes this.
  23. stanlow69
    stanlow69
    Metal trays don`t crack when you drive over them. You can just beat them back into shape.
    williebill likes this.
  24. 05snopro440
    05snopro440
    Neither do mats.
  25. 57 Fargo
    57 Fargo
    The one good thing about having a gravel floor…leaks just keep the dust down.:)
  26. Fat47
    Fat47
    57 Fargo, I'm sending you enough used oil to do your whole garage.
  27. Almostdone
    Almostdone
    Where do you buy the Kotex pads with magnets?
    John
    Kevin Ardinger likes this.
  28. Kevin Ardinger
    Kevin Ardinger
    Hahaha! Cl***ic!!!!!!! From the Tin Man’s old lady?????
    kadillackid and Cosmo49 like this.
