Technical Garage journal issues
Discussion in 'The Hokey Ass Message Board' started by Texas Webb, Jun 23, 2017.
  1. Texas Webb
    Texas Webb
    Anyone have trouble viewing the GJ?It says page can't be displayed.I can get it using google.The other sites are ok,thanks.
  2. HOTRODPRIMER
    HOTRODPRIMER
    I can't log in. HRP
    Secure Connection Failed
    An error occurred during a connection to www.garagejournal.com. SSL received a record that exceeded the maximum permissible length. Error code: SSL_ERROR_RX_RECORD_TOO_LONG
  3. KRB52
    KRB52
    from Conneticut
    No problem doing so at work at 0358 hours, EDST.
  4. Last times I was on, I had to drop the s from https, as it's not a secure site like this one. If using the hyperlink at bottom of this page, it keeps the "s", so won't link up.
  5. 32ford5
    32ford5
    from Australia
    ^^ This ^^
    I reported the error to Ryan a while ago.
  6. HOTRODPRIMER
    HOTRODPRIMER
  7. crminal
    crminal
    Used your link and it wouldn't open. Then, removed the "s" from https and it opened.
  8. 32ford5
    32ford5
    from Australia
    I just visited and was logged in so I logged out then back in again. Maybe clear some or all your cache files and try again.
    http://www.GarageJournal.com should work (no "s")
  9. Rex_A_Lott
    Rex_A_Lott
    I just posted there. You do sumting wong.:D
  10. pat59
    pat59
    The "S" is bad Mkay? :)
  11. HOTRODPRIMER
    HOTRODPRIMER
    It appears that the garage journal address listed under the Atomic Industry link is broken.
    HRP
    I was able to log in with this...http://www.GarageJournal.com
