I recently moved into a house with a garage built in the 60’s that has the old metal frame nine pane windows does anyone know where I can get the props and locks? Sent from my iPhone using The H.A.M.B. mobile app
Do I use my username and p***word from here or create a new account? Sent from my iPhone using The H.A.M.B. mobile app
My garage has 3 double pane sliding windows . I found a piece of old iron railing with the c channel at the top and bottom . I cut the bottom off marked and drilled into the casing lowered the railing into the holes about 3 inches , and bolted the top inside the c channel with 3 in lag bolts for security . Opening the windows spring and fall , and relaxing with the radio , it’s about as good as it can get .
