Garbage MIG wire..any choices left?
Discussion in 'The Hokey Ass Message Board' started by williebill, Jan 22, 2013.
  1. Squablow
    Squablow
    Count me in as another happy Forney user, although I've heard a lot of good stuff about the "easy grind" stuff.
    Also, to the OP, if you get a new roll of a name brand, please report back as to how well it worked. I'm curious to know if it was just a random bad roll, a poor quality product or a liner/drive roll issue.
  2. BISHOP
    BISHOP
    I bought some Forney wire in a pinch on a Saturday. It is good.
  3. dirtracer06
    dirtracer06
    Forney seems pretty good...only one you can get at ace hardware on a Sunday...usually i have been using us forge...both seem to work well in my lincoln...after i replaced the 15 year old liner.....
  4. repairmanrod
    repairmanrod
    from colorado
    Scratching my head!!!! Blue Demon wire is Stainless Steel. Really shouldnt be used on mild steel and you need a trimix gas to use it!
    Rod
  5. budd
    budd
  6. tlmartin84
    tlmartin84
    from WV
    I like my hobart, pick em up at tractor supply. 29.99 a ten pound roll.
  7. jimbousman
    jimbousman
    Chances are guys like Miller and Lincoln probably don't make their own wire. Worse yet they probably shop around for suppliers and sometime **** happens.
    I've switched to US Forge wilding wire. Better than the **** I was using. US Forge makes their own wire and are OEM manufactures for some of the majors.
  8. mickeyc
    mickeyc
    Ricard Finch noted author on welding and highly experienced welder
    and instructor states in one of his books. The copper coat on weld rods and wire is to facilitate the pulling of the metal through the forming dies
    during the manufacturing process. I was surprised to read this. I thought the copper was a rust inhibitor.
  9. Blue One
    Blue One
    from Alberta
    As for liner plugging, I will back up slightly and say that yes with coiled steel liners the copper can sometimes s****e off and build up and cause problems.
    That is why we have switched over to nylon liners for smoother feed. I had almost let that slip from my mind :)
    Yes, the copper helps with the drawing process making the wire and helps with feeding through the rollers afterwards.
    It is also a rust inhibitor as well so that is all true.
    The other function as I mentioned is for good electrical conductivity when p***ing through the contact tip.
  10. Engine man
    Engine man
    from Wisconsin
    The company I work for recently switched to Airgas through a national account and we started using Radnor wire in .035 and 1/16 and we immediately started having jamming problems. We had been using Washington Alloy wire. It was the cleanest wire I have ever seen. It's silver colored but doesn't seem to rust. Here's a link.
    http://www.weldingwire.com/
  11. patrick english
    patrick english
    from La puente
    Maybe you just got a bad roll.I've been using a big roll of harbor freight wire for a while.
  12. bbc 1957 gasser
    bbc 1957 gasser
    why does all the forney products say made in china on them ?
    ive had good luck with m.e.t wire
  13. Chemin
    Chemin
    I used to think the wire was the cause of bad welds but realised it was just me.
  14. ems customer service
    we use airgas but always insist that they order lincoln welding wire for us ( both mig and stick) they ***** and moan and try to tell me that radnor is the same, it is not.
    I throw thr radnor **** back in there face and tell them to order the lincoln.
    Lincoln has a big plant in cleveland that makes mig wire, it runs 24/7 to keep up,
  15. We have used HOBART brand .035 for several years. Cost a little more but has worked well for us.
    SPEEDY
  16. Engine man
    Engine man
    from Wisconsin
    After Airgas telling us we had feeder and Tweco mig gun problems we got Washington Alloy wire from our previous supplier and all of the problems stopped. When we told the Airgas salesman he suddenly can get Washington Alloy from their Chicago warehouse. It isn't much difference in price either. They must have a very high markup on the Radnor products. Don't use the Radnor mig gun parts either. We had some 1/16 tips that the wire wouldn't go through. We only use Tweco parts in the Tweco guns.
  17. Bert Kollar
    Bert Kollar
    I live a couple miles from the Lincoln wire plant and I can tell you they receive a LOT OF WIRE delivered to the Mentor Ohio plant which is drawn into MIG wire. I also have a couple beers on occasion with Lincoln employees, as recently as an hour ago, and they will tell you they draw a lot of welding wire in Mentor
  18. Just Gary
    Just Gary
    Another vote for ESAB "Easy Grind".
    Also, I use wire cleaner/lubricant. Its a package of a can of liquid and a felt tube that rides on the wire just after it comes off the spool. You squirt the liquid on the felt regularly to keep the wire from sticking.
