Technical Gas float came off
Discussion in 'The Hokey Ass Message Board' started by Nickyz129, Sep 9, 2019.
  1. Nickyz129
    Nickyz129
    Any suggestions for getting a gas float out of your tank other than pulling it and draining it.
    Seems to have fallen off the mount with the rod holding it and I can’t find it.
    I ran an antenna magnet down there but no luck so far.
    Thanks in advance.
  2. BJR
    BJR
    The float is either cork or br***, magnet is not going to get it. Pull the sending unit and see what is really wrong.
  3. Nickyz129
    Nickyz129
    That explains the magnet not working. It’s br***.
    I did pull the sending unit, the float and little rod that clips onto the unit fell off. Tried to shine a light in the tank but can’t see much.
  4. Jalopy Joker
    Jalopy Joker
    what ride are you working on?
    down where? depending on type of tank there is usually a plate at top of tank that can be removed to take care of sending unit
  5. tb33anda3rd
    tb33anda3rd
    what car? just put another one on. it shouldn't hurt any thing floating around.
    Nickyz129 likes this.
  6. Nickyz129
    Nickyz129
    It’s a 55 F-100.
    Down there (inside the tank)
    The sending unit is right on top of the tank. No issues with the sending unit. Just the float.
  7. Bandit Billy
    Bandit Billy
    Drain, remove, turn upside down and use a rubber hammer to move(bounce) the float to the sender hole. Doing it right ****s sometime but it doesn't cost you anything but a little time.
  8. Nickyz129
    Nickyz129
    Thanks bandit! That’s what I was thinking. Just filled her up too.
    Guess I’ll burn some gas then do it.
  9. Bandit Billy
    Bandit Billy
    Don't burn too much, you don't know when it's getting low! :cool:
    Nickyz129 and catdad49 like this.
