Gas Gage Bouncing
Discussion in 'The Hokey Ass Message Board' started by Miggs, Jun 13, 2010.
  1. Miggs
    Miggs
    can anyone help me out? the gas gage neddle on my '48 chevy p/u constantly bounces. it reads gas in the tank but bounces between full and the level it should stay at. how can i fix this problem? please help.
  2. Dooley
    Dooley
    from Buffalo NY
    check grounds, and a short to the hot wire
  3. johnboy13
    johnboy13
    Is the tank behind the seat? Are you sure it isn't just the sloshing gas in the tank causing the float level to quickly change?
  4. Miggs
    Miggs
    no. the tank is under the bed. it bounces like an electrical problem. it does it even standing still.
  5. Fordguy321
    Fordguy321
    from Arizona
    possibly fuelsender itself. from my expeience with the newer junk erratic quages are commonly from sender itself. my 2 cents that are worth nothing
  6. Mike51Merc
    Mike51Merc
    Some of the old senders have a capacitor in the line to buffer out the sloshes of the tank.
  7. green53ford
    green53ford
    from Wisconsin
    My 37 chevy did the same thing. Added a ground wire everything was fine.
  8. dragsta
    dragsta
    ditto to all the above. check for a loose/corroded connection before pulling your sending unit. DISCONNECT YOUR BATTERY TERMINALS FIRST!
  9. Miggs
    Miggs
    where did you put the ground wire? what did u ground?
