Gas gauge help
Discussion in 'The Hokey Ass Message Board' started by Dooley, May 20, 2009.
  1. Dooley
    Dooley
    from Buffalo NY
    Finally got all of the other bugs worked out, and got the car running good, got it inspected, etc; now my SW gas gauge stopped working.
    New sender (installed last year), good ground,(ran a new wire just now) and with the gauge getting power and grounded on the other post it reads full.
    Cannot get anything other than a empty reading, no flicker no nothing.
    took the float out and it is not full of gas and moves freely...
    I am getting 12v to the gauge.
    Help
  2. Fogger
    Fogger
    The gauge sender is a variable resistor, check it out of the tank and clipped to the gauge. Check with power to the gauge, you should have a change on the gauge as you move the float. Could be you have the wrong sender for the SW gauge. The FOGGER
  3. Dooley
    Dooley
    from Buffalo NY
    It is a SW sender, and I should have said the gauge worked fine until a day or so ago...
