Technical Gas gauges.
Discussion in 'The Hokey Ass Message Board' started by trollst, Oct 24, 2023.
  1. trollst
    trollst
    I know-knew, but for the life of me, I can't remember, can you run a 6 volt gas gauge through 12 volts and have it work accurately? Got a friend, (yes, I have friends), with a 47 chev coupe, older hot rod, probably built 30 years ago, looks to have been a cream puff back then. Looks like a nice original with mustang suspension, small block-T350, and ten bolt. Stored for a long time, woken up, put back on the road last year, but the gas gauge doesn't read correctly. All the rolling stock looks like original stuff, just looks like the drivetrain was replaced.
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    No not without a resistor.
    trollst likes this.
  3. wheeltramp brian
    wheeltramp brian
    Get a runt's resistor they work perfectly.
    trollst likes this.
  4. BJR
    BJR
    I saved this from a thread here. Let me know if this doesn't work for you guys, and I will try something else.
    vtx1800 likes this.
  5. Ford used a voltage reducer under the dash thru the 60's and early 70"s. Simple bi-metallic unit that works well. Cheap and available.
  6. wheeltramp brian
    wheeltramp brian
    I've used Those ford voltage reducers a few times but find they are unreliable when I use them. So I put the runtz reducers in. And they work perfectly every time.
    trollst likes this.
  7. RMR&C
    RMR&C
    from NW Montana
    If you get an OEM Ford gauge voltage reducer they work fine. The repro ones are junk.
    CSPIDY and trollst like this.
  8. trollst
    trollst
    Thanks boys, big help.
  9. Ebbsspeed
    Ebbsspeed
    Petejoe likes this.
  10. Petejoe
    Petejoe
    from Zoar, Ohio
    I stand corrected thx @eppsspeed
    Ebbsspeed likes this.
  11. BJR
    BJR
    I followed the instructions in the pdf I posted. I ordered the parts from the net and soldered them together. Used them on my Buick and they work perfect. Cost under $5 each to make.
