I'm trying to figure out how to connect my gaspedal linkage of my 1937 plymouth coupe. Does anyone have a good picture or a technical schematic drawing.......or something to help me out? From carb to pedal I have: carb.....linkage to firewal....linkage across the firewall to other side of engine towards driver side.....and then some loose parts and bolts and a small rod that should be connected to my padal through a hole at the bottom of the firewall. I anyone could help me out here I would appreciate it. Thanks, Sascha ps:it the original straight 6 flathead
Pictures of the loose parts and the rest of the stuff would be a very big help http://www.my-classic-car-trader.com/car_ads/uploadedimages/29639831937_Plymouth_Truck_016.jpg shows the engine end of it...although that is a truck and might be a bit different...
I allready fixed it.......the linkage that was allready in there when I bought it wasn't installed right. (upsidedown, backwards ect ect). It works fine now! Thank you for your quick reply squirrel. Sascha
