Technical gas sending unit info
Discussion in 'The Hokey Ass Message Board' started by Southside Steve, Sep 18, 2014.
  1. Southside Steve
    Southside Steve
    I have an old chevy that the previous owner put a ford gas tank into , just figured that out, kept ordering sending units and getting incorrect ones.
    my question is i ordered a 6 volt sender , the car is 6 volt, but the chevy sender is 33 ohms and the replacement for the ford tank sender is 35 ohms , does this pose any type of a safety issue?
    as in will the variable resister glow and ignite the fuel ? or will it simply not read correctly?
    thanks for any input .
    Steve.
  2. 325w
    325w
    No safety issue.
  3. Southside Steve
    Southside Steve
    Thank you, Steve , Any other input is appreciated.
  4. squirrel
    chevy used the same sender for 6 and 12v, it was 0 ohms empty, 30 ohms full. In the late 60s they changed to 90 ohms.
    Make sure the resistance changes the right direction...I know that later Ford senders are low resistance full, and high resistance empty, which is backwards from Chevy
  5. scrap metal 48
    scrap metal 48
    The sending unit is NOT voltage sensitive but the dash fuel gauge is...
  6. JeffB2
    JeffB2
    from Phoenix,AZ
