Technical Gas tank oldsmobile
Discussion in 'The Hokey Ass Message Board' started by Gentle Giant, Dec 14, 2023.
  1. Gentle Giant
    Gentle Giant
    Inspected tank clean , car has been running , repaired a rotten portion of line , removed hose from tank fitting and to my suprise no gas . Yesterday I put 5 gallons in the tank plus whatever was in there . Is there a baffle are something causing gas not to come out ? 1948 oldsmobile series77
  2. BJR
    BJR
    Pickup tube may be rotted off, or plugged.
    57JoeFoMoPar, SS327 and chopnchaneled like this.
  3. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    Ditto, BJR. I've run into that problem. To check the pickup tube for rot or plugging, put just enough gas in the tank to make the car run. run it until it quits, or drain/siphon it out a little at a time until it quits running, Then, disconnect the line at the fuel pump and remove the gas cap. Using compressed air, blow out the line and listen for bubbles in the tank. You should hear violent bubbling if the tube is good. No or weak bubbles, or you hear air the tube is bad. If the tube tests good, the air pressure should clear a plugged screen. Be sure you use good strong air pressure.
  4. Gentle Giant
    Gentle Giant
    Thanks will jump on that when sun comes up
  5. Gentle Giant
    Gentle Giant
    Thanks tube was collapsed so plugged that hole and used the bottom
