Projects Gas tank problem,my new Deuce
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Sep 22, 2015.
  1. ROADSTER1927
    ROADSTER1927
    I cleaned a tractor fuel tank with flange headed metric bolts vinegar and attaching it to the front of my zero turn mower deck. Talk about shacking it! Gary:D
  2. BradinNC
    BradinNC
    I have cleaned a few tanks using nut/bolts. If tank will fit partway into a small concrete mixer,wrap it in blanket/pad. use nylon strapping and tie it off to paddles inside tank. This is a easy way to agitate tank while you do other work. On my mixer you can change the angle and lock it in place.
    Atwater Mike likes this.
  3. BradinNC
    BradinNC
    One other method I used was on a backhoe. Could not remove the tank without alot of work. It had mold in tank which is common in old diesels. I drained tank from bottom pet****. Added 1 gallon simple green, and about 10 gallons of water. Agitated it with a air nozzle I attached copper tubing to for about an hour. Got most of the gunk loose. Then stuck water hose into tank and let run for 15 minutes. Drained and rinsed with diesel.
  4. Danny, lots of good suggestions here; just keep all the chemicals inside the tank and to keep it off of the painted surface on the outside, or you will be re-painting it.
  5. HOTRODPRIMER
    HOTRODPRIMER
    Well guys,I have screwed around trying to clean the tank and save the paint for the better part of the day,the sludge is gone but the rust is pretty bad and the tank is thin.
    Common sense at this point dictates that I am wasting my time and money trying to save a 83 year old gas tank and some red paint.
    I'm biting the bullet and going to replace the tank and avoid any problems in the future.
    I appreciate all the comments and a few worked real well,but like I said earlier,the tank is very rusty and very pitted in the bottom,I would hate to install it and it start to leak. HRP
  6. da34guy
    da34guy
    Good move Danny, like I said earlier, been there done that.
    lothiandon1940 likes this.
  7. Rex_A_Lott
    Rex_A_Lott
    Some days you get the bear, some days the bear gets you. Dont ***ume the new tank will be all clean and bright and ready to go, rinse it good with some gas, diesel fuel, solvent etc, to remove any sort of cosmoline and who-knows-what-else where it may have been in a wharehouse or worse. Good Luck!
  8. HOTRODPRIMER
    HOTRODPRIMER
    I talked to Allen Mason yesterday and he gave me a good price on a tank,he said the new tanks a sealed in a plastic bag so there wont be a problem with rust,I just need to do normal prep work before painting. HRP
    lothiandon1940 and dana barlow like this.
  9. timwhit
    timwhit
    You'll sleep better.
    lothiandon1940 and HOTRODPRIMER like this.
  10. HOTRODPRIMER
    HOTRODPRIMER
    I slept pretty good last night Tim,of course there was a nightmare about how much a new tank is gonna cost but peace of mind is worth it. HRP
    clem likes this.
