Technical Gas tank sealer?
Discussion in 'Traditional Hot Rods' started by AGELE55, Oct 29, 2022.
  1. AGELE55
    AGELE55
    I have a 1927 Willies Knight in need of love. I'm attempting to tumble it to remove the rust scale inaide and then thinking I wsnt to apply a high quality rank tank sealer.
    Any recommendations?
  2. Kevin Ardinger
    Kevin Ardinger
    A place in Norfolk Va will coat them with a rubberized coating but obviously that’s a bit far from you. Culpepper radiator. I’ve done several motorcycle tanks with a product called Kreem that works well.
  3. kabinenroller
    kabinenroller
  4. Buckster
    Buckster
  5. squirrel
    If it doesn't leak, I'd leave it alone....then you won't have to worry about the sealer flaking off due to whatever it is that likes to make it flake off.
  6. BamaMav
    BamaMav
    from Berry, AL
    I’ve used a product from O’Reiley’s called RED KOTE. Been in my Lincoln tank probably 7-8 years, also used it in a couple of farm tractor tanks. So far, no problems with it peeling or chipping. Gas doesn’t soften it like some of the others. Stopped the rust particles you can’t seem to always get out from clogging the filter and carb on mine. Follow the instructions on the can and you shouldn’t have any problems.
    deathrowdave likes this.
  7. saltflats
    saltflats
    from Missouri
    How hard would it be to build a new one if it is that bad.
    Budget36 likes this.
  8. deathrowdave
    deathrowdave
    from NKy
    I have sealed many old Harley tanks , Red Kote is the best product I have personally used . I will not even try another product .
  9. Both are good choices, Red Coat in 65 Suburban and 14 years no problem. Just hard to find locally.
    Used KBS on last tank and followed their directions and cleaned tank with solvent, prep and sealed and working, as it should,
    Have had great luck with all KBS products.
  10. HOTRODPRIMER
    HOTRODPRIMER
    We were on our way to Louisville and my pal Gary started having trouble with the fuel filter clogging up, it didn't take long to realize the sealer was breaking down, we realized on the side of the interstate wasn't the place to clean out the tank so another member of the party drove a few miles back to a small town auto parts house and bought a hand full of in line filters.
    We finally got to Louisville late in the day and used most of the filters along the way, that evening after we had dinner we removed the gas tank on Gary's 34 and found a radiator shop the next morning to vat the tank, we picked it up that evening and the installed it in a thunderstorm, we got the tank back in the car and he was able to drive his car to the show on Saturday.
    From my experience I wouldn't use a tank sealer, In reality there was no reason for putting that stuff in the gas tank. HRP
  11. Beanscoot
    Beanscoot
    On my car with a rusty tank I added a gl*** sediment bowl type filter in addition to the canister filter.
    This has reduced my filter consumption by at least half.
    I did use one of the tank liners in another tank that I got chemically stripped (and soldered up all the little holes), to hopefully protect the bare steel.
    New tanks have a terne coating in them, once this is gone the steel will rust very quickly.
  12. X38
    X38
  13. I've had good luck with a few different sealers over the years. Just be sure ALL the loose debris is out and the inside is DRY!!! After coating, let it set with all ports open for LONGER than it says in the instructions! Good luck...
  14. KKrod
    KKrod
    I've had my 32 gas tank sealed with a liquid coating for about 20 years. Sitting up several years with the ethanol based gasoline in it has caused small bubbles all inside the tank. Not sure what to do to remedy the problem. So I would recommend not coating a tank.
    Budget36, hotrodharry2 and AGELE55 like this.
  15. footbrake
    footbrake
    Best to buy a new tank or have one made.
    Budget36 and da34guy like this.
  16. manyolcars
    manyolcars
    POR15 tank sealer is awesome. After coating the inside, pour out the leftover POR15. I left the tank to drain and it tried to seal the 5/8" drain hole. Kreem and some others are just liquid PVC
  17. I bought tank sealer from Caswell quite a few years ago and it failed. I have no idea if the stuff they sell now is the same stuff they sold then though. I had a chunk of sealer partially block my fuel line and cause me issues at highway speed. Ended up cutting a 4" hole in the top of the tank so I could get my arm in there to peel off as much as I could. When I had the tank out to remove what I could of the sealer, I thought ahead this time and installed a "filter sock" on the tank end of the fuel line. I had a spare G-body sending unit handy so I grabbed the "filter sock" off it. The "filter sock" I am talking about is the gold/bronze/yellowish colored thing in the top left of the image below. I have no interest in using gas tank sealer ever again. Funny thing is, my tank was actually in decent shape and I thought the sealer was a bit of insurance considering the fact that my tank was from 1938 ... I should have just left well enough alone.
  18. oldolds
    oldolds
    Like Niel Young said, Rust Never Sleeps. The biggest problem with coating a tank is you do not know if you got all the rust out or treated before you coated it. I would imagine most of us rush the job. Then there is no way for most of us to see inside the tank to be sure. Inspection cameras are cheap now but not 20 years ago. A new tank would be the way to go. If there is one made for your car.
    That being said I have used a couple different products to seal tanks over the years. I have not seen any problems, but have sold most of those cars and tractors. All were done before ethanol was added to gas. I have heard that causes problems with older sealers.
  19. 1971BB427
    1971BB427
    from Oregon
    After getting stranded twice far from home in my late 60's Suburban due to someone putting sealer in the gas tank, I'd never use sealer! I'd simply clean it as good as possible, and then use it.
    The sealer used on my gas tank came off in big sheets, and the piece I found after dropping the tank was a "sheet" of sealer about 8"-10" in diameter and had completely wrapped itself around my pickup in thhe tank, and starved the fuel pump, stranding me about 200 miles from home.
    I don't trust any of it now.
    AGELE55 likes this.
  20. Kevin Ardinger
    Kevin Ardinger
    I think Ford had a problem with some of their diesel tanks delaminating and that’s a factory job. Caused a big mess with injectors!
  21. FWIW... For the cost and peace of mind, buy a new tank if they are available. I have a serious rust and sediment issue on my 58 Ford. For $300 I have a new tank and no worries about reliability.
    olscrounger and ekimneirbo like this.
  22. hemihotrod66
    hemihotrod66
    Had to modify the tank on my 34 when I narrowed the frame for bigger tires...Had a outfit in Hemmings called Tank Renue line mine 15 years ago and so far no issues..
  23. ekimneirbo
    ekimneirbo
    Unless you are trying to do more of a restoration than a hot rod, I'd try to find a new replacement tank. If you ever break down on the road, it will probably cost you as much as a new tank would cost. I think several of the products available do a really good job, but getting rust out of seams before applying the product is hard to do.:)
    olscrounger likes this.
  24. Rocco611
    Rocco611
    from Madera Ca.
    I have used the Kreem products with good results. A hand full of Hex Nuts dumped in the tank helps break up the rust. Its really hard to shake a car fuel tank hard enough to get it clean though. Taking proper safety precautions on tanks that cant be replaced with new, I have cut a large square out of some tanks in an incon****uous spot then sand blasted the inside then weld it up again and seal it with Kreem.
