Gas tank storage
Discussion in 'The Hokey Ass Message Board' started by chopped, Apr 4, 2013.
  1. chopped
    chopped
    Got a gas tank yesterday that I won't be using for up to a year. Was going to tape up the openings and stick it in the attic. Will moisture ac***ulate, how can I store it?
  2. shinysideup
    shinysideup
    from ruskin, fl
    I ***ume you mean new tank? If so and condensation is an issue tape rags over openings. Taping them airtight wont help keep out moisture, its already inside in the air,let that circulate and you are fine.
    If a used gastank, re-think the attic plan.
  3. bobj49f2
    bobj49f2
    Dump some oil in it and rotate until it's completely coated. You can rinse it out when you need to use it.
  4. HOTRODPRIMER
    HOTRODPRIMER
    If you put it in the attic with the holes covered it's going to sweat and have a lot of moisture,,put it in a closet or under the bed if momma will let you. :D HRP
  5. theHIGHLANDER
    theHIGHLANDER
    Let it breathe in a cool dry place. Sealing it up and storing in an attic sounds like a lot of temp change. Metal going from hot to cold tends to "sweat" just a little. I agree with rags, and I'd store it in a ba*****t, if you have one.
  6. Willy301
    Willy301
    The big tea bags full of silica are available for keeping the moisture out of it, but I agree that the attic is a bad idea. The oil idea is a good one too, if done sparingly, you wouldn't even have to rinse it out, it would just provide a little upper cylinder lubrication on start up. If too much oil is used, it would also serve as a mosquito fogger :)
  7. chaos10meter
    chaos10meter
    from PA.
    Tape a screen on the openings to keep the critters out.
  8. chopped
    chopped
    Two windshields occupy the under bed storage. It's a good condition used one that was a gift. Thanks for the ideas, I'll find someplace more suited.
  9. williebill
    williebill
    The good stuff stays in the house. Warm in the winter,cool in the summer,no problem with sweating or humidity,clean metal stays that way. But I'm not married anymore,so I can put stuff wherever I want.
