Gas tank strap insulation?
Discussion in 'The Hokey Ass Message Board' started by Cerberus, Nov 1, 2011.
  1. Cerberus
    Cerberus
    I am in the middle of installing my avatars GM 70's gas tank. The straps are in excellent condition and fit in the bottom of the tanks indentations. My question is: Is there suppose to be some kind of rubber insulation that fits between the tank and the straps? Or, is it merely the tanks bare metal against bare metal straps? Or does it make a difference?
  2. 29moonshine
    29moonshine
    i use 2 layers of 30# felt the with of the straps
  3. I used a couple of pieces of rubber on mine.
  4. Sir Woosh
    Sir Woosh
    Reinforced rubber strips between the metal.
  5. 4-pot
    4-pot
    I use strips of 90# roofing felt [ tar paper ]. Have used it for 50 years on all kinds of vehicles.
  6. General Motors used "felt paper" as a factory insulator to go between the straps and the tank. If it worked for the General, it'll work for you.
  7. HJmaniac
    HJmaniac
    I have heard some guys using strips of inner tube. Find a Schwinn Stingray with a flat tire and use the inner tube. That will keep it "traditional" :D
  8. fleetside66
    fleetside66
    When I read your suggestion, I was thinking that that was a really good idea. Then, it dawned on me that I did that a couple of years ago. Wow..I had a good idea!
  9. 31Apickup
    31Apickup
    An old serpentine fan belt will work also. It's a bit thicker, but worked perfect on one of my projects.
  10. BOWTIE BROWN
    BOWTIE BROWN
    Yep .....all the above. No metal against metal.
    "AND THE BOWTIE ROLLS ON"
