Technical Gas tank
Discussion in 'Traditional Hot Rods' started by WP38, Apr 23, 2017.
  1. WP38
    WP38
    I installed a 1968 Camaro gas tank in my truck. I thought it would be a good idea to put the filler under the plate holder. I took the truck out for the first time bottom driveway. Slight hill. Gave her some gas and laid some rubber LOL. I found the gas came out the back from the vent cap. Thought I would pass this on. I think I will have to change the filler to come streight up through the wooden floor.
  2. oldolds
    oldolds
    Put a non vented cap on and vent the tank another way
  3. There ya go. HRP
  4. WP38
    WP38
    Since i'm not using the original fuel pick up line I guss I can leave that open. Not sure about the safety
  5. wraymen likes this.
  6. harpo1313
    harpo1313
    from wareham,ma
    Put a hose on it and run it as high as you can ,maybe up a stake pocket,put a loop on it so the end is facing down to keep rain out of it .
    King ford likes this.
  7. WP38
    WP38
  8. Jalopy Joker
    Jalopy Joker
    if vent hose is not high enough gas will possibly flow out
  9. WP38
    WP38
    I picked up a remote vent thanks for the safety tip
  10. Bandit Billy
    Bandit Billy
    If the tank is aftermarket the caps fit like crap and that issue is common I have found especially when using the aftermarket caps made somewhere west of California. I replaced my tank with a tanks Inc unit, they use their own proprietary cap that seals just fine, even under hard acceleration. Oh, they offer it in stainless too so you can polish it (the tank, not the cap).
  11. ...quit goin uphill and peeling out,..seriously, those tanks were used in Camaros and Novas and worked fine with the right cap.
    Bandit Billy likes this.
  12. you broke your transmission with all that horse play :D
  13. czuch
    czuch
    from vail az
    I've taken a brass flared nipple, 1/4", from the hardware store and drilled a 1/4" hole just below the gas cap.
    Push the nipple theough and put 1/4" fuel hose with a new hose clamp. Run it about 3 ' and loop it through the frame a couple of times. Never smelled gas, never burned a car,,,,, because of that.
