Technical Gas tank
Discussion in 'The Hokey Ass Message Board' started by 29 coupe, Feb 27, 2022.
  1. 29 coupe
    29 coupe
    With the gas tank being inside the cab of a 32 ford pickup how did you fill? Was the seat hinged? Any pictures
  2. Budget36
    Budget36
    You sure they were in the cab?
  3. dirt t
    dirt t
    The tank on 32,33 and 34 was mounted at back of frame.
    Budget36 likes this.
  4. lurker mick
    lurker mick
    I believe the gas tank on a 32 ford pickup is under the drivers side seat.
    Mick
    fiftyv8 and Budget36 like this.
  5. 325w
    325w
    It was under the seat on a pickups and panels.
    fiftyv8, Budget36, X38 and 1 other person like this.
  6. Budget36
    Budget36
    I’ll be darned, figured they were
    like the cars. I ***ume the filler is out the side of the cab then?
  7. 2935ford
    2935ford
    32 Ford pickup gas tank was under the p***enger side seat. You had to lift up the seat, remove the gas cap and fill.
  8. fiftyv8
    fiftyv8
    from CO & WA
    Yep, under the seat in pickups.
    I had a 1933 pickup and was considering moving to a sedan style rear tank or run both tanks as duals.
    Maybe somebody has done this already?
  9. Rand Man
    Rand Man
    Are you full-fendered or high-boy? Saddle tanks can work with fenders.
  10. Budget36
    Budget36
    And the answer comes in, I’ll be darned!
  11. 2935ford
    2935ford
    Saddle tanks can solve the problem but they are a bit fussy. Filling them is a pain as they fill from each side and you don't get to fill them all the way up. I had them in my '29 Roadster.
    I put a Tanks tank in the rear. Cut a filler hole in the bed. Worked great.
  12. KevKo
    KevKo
    from Motown
    No saddle tanks for '32's, no place to put them. Model A's, yes, under the splash aprons. No splash apron on a 32.
  13. Rand Man
    Rand Man
    Oops! You are correct sir. What in the world was I thinking?
