gas tank
Discussion in 'The Hokey Ass Message Board' started by chunk40, Mar 31, 2012.
  1. chunk40
    chunk40
    ok took the dodge for its first ride and found out the gas tank has a few pin holes in it..........does anyone know if I can get an aftermarket tank or is there a good sealer out there that would not clog up the fuel pick up?????the car is a 1950 dodge wayfarer business coupe.........thanks all........
  2. Retro Jim
    Retro Jim
    I would Google for a search and go from there . Not a popular car for a tank but never know .
    You can try a radiator shop to have the tank flushed and cleaned . Then they might be able to weld it up for you and seal it . DON'T try cleaning it yourself and welding it . You just might find out how bad you didn't get all the fuel cleaned out ! That can be very dangerous so leave it to the Professionals !
    Try this place - http://www.buycheapr.com/us/result.jsp?ga=us22&q=1950+dodge+gas+tank
    Retro Jim
  3. KoolKat-57
    KoolKat-57
    from Dublin, OH
    A friend of mine got a new tank for his '50 Coronet.
    I'll ask him where he got his and PM you next week
    His has a complete drivetrain out of a Dakota pickup 360 V8!
  4. AfterhoursFab
    AfterhoursFab
    from NJ
    Youll want to have it boiled out if its all gunked up, it has to be really clean to seal it. I use the tank sealer from KBS Coatings, works great!
  5. cmbrucew
    cmbrucew
    from Socal
    After you get it cleaned, you can tin the affected area, and solder it with a big soldering iron. The type you heat with a blowtorch. Safe and effective.
    Bruce
    Works good
    Lasts long time
  6. ROADSTER1927
    ROADSTER1927
    Not recomended but ALL METAL body putty can be used on the outside to seal leaks. Gary
  7. chunk40
    chunk40
    thanks everyone......cleaned off the outside of the tank and there are more pin holes in it than a screen door............
  8. Cerberus
    Cerberus
  9. silversink
    silversink
    I use pennys to solder on the tank after tinning it. They work great and there is always plenty around.
