1952-59 Ford Gas Tank
Discussion in 'Off Topic Hot Rods & Customs' started by Nite Owl, Jan 30, 2012.
  1. Nite Owl
    Nite Owl
    Well, I bit the bullet and bought a gas tank from Auto City Cl***ic for my '54 Customline. They didn't have any 54 tanks and didn't know when they would get any, so I ordered one for a '55. It got here and was almost identical to the '54 tank. The filler neck is bent a little different, but I think I can cut the neck and put it back together with a piece of rubber hose between the two pieces and it will work. They are made in Tiawan, but look to be of pretty good quality. Besides, the price was right. We'll see how it works out.
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    Let us know if it works,it seems the 55-56 tanks are around but not the 52-54 tanks and post some pictures if possible.
  3. Seamus24
    Seamus24
    from maine
    I tried ordering a tank this weekend from Auto City Cl***ics and received an email Monday stating they were backordered until May. This is also for a 52-54 tank. I took another reallly good look at my tank inside and out and figured I'd go the POR 15 Sealer route.
    Tanks are big money for these year cars. I think Mac's is fetching $345 at last check!
  4. Ole don
    Ole don
    The tank in my 55 has a rather large flat spot on the top. Plenty of room to cut a window big enough to reach down to change the sock on the end of the pickup. Then I used a cork gasket and sheet metal screws on the new cover for the hole. An inner tube gasket does NOT work, use cork. I made a new filter from fine window screen doubled over and wired on.
  5. baker53
    baker53
    I was able to install the Auto City Cl***ics tank into my 53 Victoria with just minor modifications to the body where the filler tube goes through. I did have to use longer fasteners at the rear to fasten the straps. I put additional rubber spacers between the top of the tank and the trunk floor. This lowered the tank a bit which provided clearance for the filler tube, but required the use a little longer fastener for the straps. The filler cap is closer to the license plate bracket, but it does not touch it.
  6. JeffB2
    JeffB2
    from Phoenix,AZ
  7. Nite Owl
    Nite Owl
    The '55 tank was $139. Not a bad price and I think I can cut the neck and piece it back together pretty easily. Looks like it will be a couple of weeks before I can get back to it, but I'll definitely take pictures. Now, posting them on a computer is a whole 'nuther animal.
  8. JeffB2
    JeffB2
    from Phoenix,AZ
    If you have a problem posting the Pics send skoh73 a pm,He is our resident expert that can help you.
  9. 1 Ford fan
    1 Ford fan
    With a new tank could you not take your 54 neck and weld it to the new 55 tank?Gerry
  10. Nite Owl
    Nite Owl
    On the '55 tank I bought, there is a ****** on the driver side, top front of the tank. I'm pretty sure it is for a vent, but I don't know how to vent it. My '54 had a vent in the top of the tank going back to the filler neck. Is there a hose vent that attaches to this ******? If so, where does it vent to? Any body with a '55 that can tell me what yours looks like? Thanks.
  11. old lady's mad
    old lady's mad
    on my 55 there is just a pipe or fuel line that gose up the inside if the fender well and loops over, i put a fuel filter on top of mine so it would not get dirt in it
  12. Nite Owl
    Nite Owl
    Thanks Old Lady's Mad. I'm wondering if I even need it as long as the cap is vented???
  13. old lady's mad
    old lady's mad
    with normal driving i would say no. i pluged mine of first with a vented cap. but if you have a high draw of fuel like a wide open 4bbl you might create a va***e on the tank.
  14. raceron1120
    raceron1120
