Is there supposed to be a gasket between the intake and exhuast manifold? Theres the carb, then the gasket between the intake and carb, then the intake and the exhaust manifold (between these two)? the manifold I had on there that cracked on me, as I took that off I noticed no gasket between the two. This is for the 215 inline 6.
They definitely need a gasket, even if they're machined they need a gasket. The intake/carb setup on that motor is so hard to get torqued right, you need that bit of gasket to take up whatever slop might be in there.
Fel Pro makes them. I know I went with a much thicker aftermarket style when I did the different manifolds. I know there was one in the box when I redid the motor so they must sell it separately. The part number for Fel Pro is MS 9960 and they're $11.67 from Rock Auto and they're in stock from what I can tell.
