Gasket material for ethenol.
Discussion in 'The Hokey Ass Message Board' started by 32 hudson, Oct 12, 2011.
  1. 32 hudson
    32 hudson
    I need flat gasket sheet material for my gas tank build. What is the best to use for ethenol gas ?
  2. Rocket Scientist Chris
    Viton is best. You can get one foot square sheets in 1/32 and 1/16 inch thickness from smallparts.com. It's a little pricey, but it does the job! :)
  3. 32 hudson
    32 hudson
    Thanks. I checked smallparts.com but could not find flat sheet stock only viton o rings. What are the search words to find it.
  4. Rocket Scientist Chris
    Do a general search for "viton". When the results come up, on the left will be a product category list. It'll be under "rubber" in the material section. Hope this helps! :D
  5. chaddilac
    chaddilac
  6. 32 hudson
    32 hudson
    Thanks chaddilac. That is pricey for sure. well I did ask for the best. I wonder if there is any thing else that I could get by with less exspense. I need to make a flange gasket 7 3/4 inches square so 12"x12" sheet would work.
