I'm looking for some advice on full gasket sets for A 364 nailhead.I have herd from a lot of people that Fel-Pro are the ones to go with. I've been looking around for a wile and can't find much for the 364. Is the kit for the 401-425 the same as the 364? Also if you could give some info on were I could buy one that would be great. Thanks Chris
The kits for the 401-425 should work. The cylinder bore diameter in the head gaskets will be a little bigger, but other than lowering the compression a little should do no real harm. You should be able to get Fel Pro from most good supply houses. I know NAPA picked up the Fel Pro line last year. I can get you the contact info for my local NAPA if you don't have luck otherwise. I am pretty sure they would ship to you up there, but would have to check to be 100% sure.
