Technical Gasmonkey fleetmaster
Discussion in 'The Hokey Ass Message Board' started by minijoey, Apr 10, 2018.
  1. minijoey
    minijoey
    so unregarding the show...
    I'm working on a flat black Oldsmobile 1947 coupe.
    The style I want to make it in will be kinda like the 48 fleetmaster made by gas monkey.
    Ofcourse not a copy, But similar.
    Could somebody tell me (guess) What kind of wheels and tires they've used?
    I've got 15" and I think they look too Tiny for the wheel arches.
    (Yes my olds will be lower)
    48 fleetmaster
    47 olds
    Thanks! Joey
    oldsjoe and chryslerfan55 like this.
  2. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    I like the looks of yours better already. Maybe drop it a tad more but that's it.
    Countn'Carbs likes this.
  3. GMG used off the shelf chrome steelies
    your wheel arches are shaped different then the chevy fleetmaster
  4. steinauge
    steinauge
    from 1960
    Nice car. I believe if you use a taller tire like an L-78 15 with the black sidewall out it will improve things
  5. 0nedon
    0nedon
    Looks good- try 900x20! lol
  6. minijoey
    minijoey
    Thanks you all!
    My fenders are made wider, Some welding has been done and lots of bondo....so Gonna fix that.
    Rear fenders of the Chevy are narrower from factory But should fit the olds.
    In july I'm picking up this project and will start a project page.
  7. Tim
    Tim
    from KCMO
    They are probably 15” wheels. The wide white makes them look different than your thin whites on top of the other things already pointed out
    lurker mick likes this.
  8. this olds is sweet
    I like this chevys roof line
  9. Fedcospeed
    Fedcospeed
    Anything 47 Olds and *** MONKEYS in the same reference is blasphemy. Anyway stock 16" is what id keep it at
  10. jimmy six
    jimmy six
    In places around LA 22's would be the minimum....26's with a tire at 28" is the new normal.
  11. Deuces
    Deuces
    Someone actually watches that show?????.....
    mad mikey likes this.
  12. flynbrian48
    flynbrian48
    Hahahahahahahahahaha!
    Deuces and mad mikey like this.
  13. Harland grunder
    Harland grunder
    *** monkey garage
  14. Dangerous Dan
    Dangerous Dan
    086.jpg 086.jpg 086.jpg 086.jpg 15 by 7 smoothies with speedway spiders. Plugged extra lug nut hole with push in plugs from Ace hardware
  15. 117harv
    117harv
    We made it to post #9, farther then I thought we would.
  16. Deuces
    Deuces
    :D
  17. Deuces
    Deuces
    Yep! That one....
  18. Mr48chev
    I think what is throwing you off is those 70's fender flairs for the extra wide tires on deep rims that someone had on the car in the past. Sounds like you have that part figured out though. Once the flairs are gone the wheel and tire combo you have won't look lost in the opening.
