Gasoline grade for a straight 6
Discussion in 'The Hokey Ass Message Board' started by CrazyWhiteMan, Apr 15, 2012.
  1. CrazyWhiteMan
    CrazyWhiteMan
    from Odessa, FL
    Im about to put my 51 Dodge on the road and I was wondering what grade of gasoline to put in. I am using ethanol free 87 grade with octane booster now while working on it. Can I use 89 or 93?
  2. stuart in mn
    stuart in mn
    Is it the original engine? Is it modified? If it's stock there's no real reason to run anything more than 87 octane.
  3. tfeverfred
    tfeverfred
    What are the engine specs?
  4. moefuzz
    moefuzz
    Why would anybody need an octane booster for something that has a compression ratio of less than 7:1?
    Stick with good old regular.
  5. tfeverfred
    tfeverfred
  6. Ebbsspeed
    Ebbsspeed
    I wouldn't even be wasting my money on anything other than the lowest grade gasoline you can buy. A 1951 Dodge flathead six will almost run on an alcoholics' piss.
  7. 38Chevy454
    38Chevy454
    The very low compression ratio makes any gas just fine. Use the cheap stuff. hogher octane is just wasting money.
  8. CrazyWhiteMan
    CrazyWhiteMan
    from Odessa, FL
    Thanks everybody. Im mechanically retarded. It is the original, untouched engine.
  9. Ha Ha Ha!!!
    Now that's freakin' funny!!! :D
    I like this guy! :cool:
    But as far as your engine goes.... Try pissin' in the tank after a couple of beers. That should be enough octane for it. :eek:
  10. 55 dude
    55 dude
    lets see a picture of your ride!
  11. afaulk
    afaulk
    I wish everyone would "read up" on the octane rating method used for pump gas R+M/2, and how it relates to the old method of rating octane. Modern pump gas is really pretty darn good stuff if ya leave out the ethanol.
