Technical Gasoline Sealant
Discussion in 'The Hokey Ass Message Board' started by rockable, May 21, 2025.
  1. rockable
    rockable
    I used to use Dow Corning RTV 730 for sealing gas tanks, carburetors or other places where a gasoline leak proved difficult to stop. It works really well but is ridiculously expensive.
    I had a leak on my 49 Buick around the sending unit for the fuel gauge and it was mostly leaking around the screw threads when I stopped the tank off. I needed something to apply to the threads to stop the spiral leakage permanently.
    So, I did a search for gasoline resistant RTV and came up with a new one that seems to work really well and is a lot less expensive than the Dow Corning 730. It's made by a company called Silicone Solutions. Here is a link. Hope it works for you.
    https://siliconesolutions.com/ss-300.html
    Bangingoldtin likes this.
  2. 2OLD2FAST
    2OLD2FAST
    from illinois
    Keep in mind , resistance doesn't mean proof ..
    tb33anda3rd likes this.
  3. sixty3
    sixty3
    from Erie, Pa.
    Your post is right on time. I have the same issue with leakage around the sending unit on my O/T pickup. When I installed the unit I used a Permatex sealant recommended by the tank manufacturer. I do not recall the product name, but it hasn't worked well. Next time the tank needs filled I plan on attempting to seal it again. I'll look into your suggestion.
    rockable likes this.
  4. blue 49
    blue 49
    from Iowa
    I happen to have part of a can of gas tank sealer from trying to save an old tank years ago. I have used a smear of it on the gaskets and a dab on the threads of the screws on the last few tanks I've done. It's also expensive, but if you happen to have some, it works good.
    Gary
  5. rockable
    rockable
    Nobody is going to put "proof" on their label.
    Fitty Toomuch likes this.
  6. Bandit Billy
    Bandit Billy
    The Permatex stuff I have used never hardens, it remains in a gel state, and I have never had it fail. Of course, now that I said that...
  7. 1952henry
    1952henry
    Is that the orange Permashield? Just “fixed” a leaking fuel shutoff for OT tractor with a piece of felt drenched in Seal All, so far so good
    dogwalkin likes this.
  8. 40FORDPU
    40FORDPU
    I've also had success with Seal All.
  9. leon bee
    leon bee
    Seal All for me too, but it's getting hard to find around here.
  10. Doublepumper
    Doublepumper
    from OR-WA, USA
    I've used Hylomar to seal fittings and gaskets exposed to gasoline. Worked good for me.
    Jagmech and warbird1 like this.
  11. 1952henry
    1952henry
    Heard fantastic stuff about Hylomar, used by high end English automakers. Was about to order some, then stumbled on this. Supposed to be equivalent. Haven’t tried it yet, am going to use it to seal differential where tubes are inserted on my MH front axle. IMG_1489.jpeg
  12. 2OLD2FAST
    2OLD2FAST
    from illinois
    I see many things that are waterproof , acid proof , etc.
  13. rockable
    rockable
    I've used this, it works ok. The RTV I posted is better, IMO.
  14. 1952henry
    1952henry
  15. RDR
    RDR
    JMHO.. any silicon in the fuel system... and a weekend ruined..
    Good Luck
    2OLD2FAST likes this.
  16. I have used a goop that is usually used on steam and chemical fittings, called "Stag". It hardens, but not rock hard, and has finally sealed the gasket on my fuel sender unit. There should be an equivalent available up north.
  17. Jagmech
    Jagmech
    Henry, have used the permatex sealer on several sending unit/ pick-up tube cork seals , after a couple years still holding, smear it on both sides, let it set up for 24 hours before filling tank.It appears identical to some hylomar I still have .
  18. squirrel
    I use sealing washer on the screws, like GM did....
  19. tb33anda3rd
    tb33anda3rd
    I started throwing the rubber gaskets that come with sending units out and making my own with the screw holes punched a size smaller so the screws have to be "screwed" through the gasket. no sealer and no comebacks.
    the sealer I would use would be "aviation gasket sealer".
    jimmy six likes this.
  20. pprather
    pprather
