Technical Gasser brake caliper ID help
Discussion in 'The Hokey Ass Message Board' started by bchctybob, Nov 4, 2015.
  1. bchctybob
    bchctybob
    I could use a little help from the HAMBERSs to ID the calipers/brakes on the front of my latest acquisition. I'm in the process of getting this old '48 Austin g***er up and driveable.
    The front calipers were stuck - one closed and one open. I have them working again but in the interest of safety I would like to replace them. I'm not sure exactly what they are. I think they are VW type 2, but the images I'm seeing show two pins retaining the pucks where as mine have a single pin. The bolts holding the calipers to the bracket are approx 2 1/4" apart. None of the local auto parts stores stock the VW calipers so I could compare them. Here are some photos to see if anyone recognizes them. Thanks.
  2. dave lewis
    dave lewis
    from Nampa ID
    Try late 60s volvo..
  3. stimpy
    stimpy
  4. BOBCRMAN
    BOBCRMAN
    from Holly
    I have the same setup on the front of my "T bucket". Early seventies VW.
  5. bchctybob
    bchctybob
    Hey, thanks for the info. HAMBERs come through again. I had something similar on my '27 T roadster many years ago but I just couldn't for the life of me remember what they were. Alright, I'll try to get some and get this thing driveable.
    The master cylinder is a strange deal too, a big old cast iron ***embly with the pedal and pivot built in. It seems to be working fine. The rear is Olds/Pontiac with drum brakes. Other than a seeping axle seal all's well back there, so far.
