Hot Rods Gasser Gasser Gasser!! 1962 Falcon Futura with a Nailhead??
Discussion in 'The Hokey Ass Message Board' started by Chuckles Garage, Dec 16, 2009.
  1. 440JIMR
    440JIMR
    As mentioned above, move the letters forward and then use lace or fish gill background. I love the car by the way!
  2. bbc 1957 gasser
    bbc 1957 gasser
    i like it all white i think the red gives it a 70s sox and martin look
  3. UnsettledParadox
    UnsettledParadox
    wild cat and strange bird are an odd couple!!
  4. AnimalAin
    AnimalAin
    Good looking concept for the paint. I'm sure you will fiddle with it as you get closer to putting the colors on, and get it just right.
  5. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    Here they are changed up a bit.
    Not sure if it will say "WILDCAT POWER" "401 POWER" "445 WILDCAT" "NAILHEAD POWER" ETC.......
    There will aso be some water transfer decals on either the side or back window(s)
  6. I like this one but not sure if I like the way "Chuckles Garage" is, what if you centered it above the wheel or left it like it was in the original pic and did a little airbrush bird or caricture of the car smoking the tires in a wheelie between the door and rear wheel opening.
  7. Opinions are like assholes, but the way the Chuckles Garage went over the wheel radious looked great but the Strange bird centered on the door looked good!! Just another asshole,,, uh opinion though!!
  8. Oh and maybe the red stripe could have a bird head shape in the front, behind the headlight!!! Like Mr. Horsepower only more vicious!!! Like the bird on the old I SPY cartoons or such!!!!!!
  9. Try Spy VS Spy!!!
  10. . . . it appears that at least two of us assholes have the same opinion :D ;)
  11. Muttley
    Muttley
    Let me know when/if you need anything. Will you be at Eagle Field next month?
  12. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    I could use a pair of American Racing decals. Whacha got?
  13. Muttley
    Muttley
    I'm out of those right now, I'll be getting more stuff soon. I'll let you know when I make the trip to the old dudes house to raid his stash again.
  14. MBTex
    MBTex
    Keep up the good work. Looks great.
  15. mart3406
    mart3406
    from Canada
    A few ideas/suggestions and some more questions...... I think the idea
    posted by "Stewed" to incorporate the old, infamous "Mr Horsepower"
    bird - (http://www.jalopyjournal.com/forum/a...8&d=1270836808 )
    in a slightly stylized and (even) more vicious looking version of him, - into the
    paint scheme, iwould be absolutely classic and very cool! And it'd definitely be
    period correct' and also in the case of "Strange Bird", extremely 'theme' appropriate
    too!! One possibility - if you decide to use the "Mr Horespower" bird in the paint
    design. - to 'stylize' and personalize him a bit - what about replacing the cigar in
    his beak with something like a connecting rod, perhap???!!!! The idea being, that
    he - ie - "Strange Bird" - has just destroyed the competition and is carrying off
    and/or eating a connecting rod from his latest victim!!!! :eek::)
    It think I read earlier, that your plans were not to use a hood at all?? Not that
    it really matters , but just for authenticity sake, I'm pretty sure that hoods were
    required on gas class cars - at least those running per NHRA rules. Old class
    rules aside, I think too, the car might look better/smoother/more finished with
    a hood. Once you cut the center out for the blower and carbs to stcik through,
    it's not going to weigh anything anyway. One possibilty that might look *really
    good* - rather than running no hood, - or a full hood, with the center cut out
    for the blower and carbs, as most guys do, - what about, maybe, cutting the
    front section off the the hood and just using that part of it - from the grill, back
    to just in front of the blower belt? That would still give a 'hoodless' look and
    completely expose the engine and the beauitful tin and chassis work, but would
    give a smoother (and more aerodynamic) look to the nose of the car, compared
    to running no hood at all.
    About cooling. Are you planning to run a radiator? if so, an actual functional
    one that would allow the car to be driven or run for some lenghth of time,
    other just a pass down the quarrter? It might be nice have a functioning
    cooling system that would allow you to drive in the pits (or drive the car
    around a bit at a car show etc. ) and also be able drive, rather than have
    to be towed back on the return road after a pass. 'Back in day', gas care
    were required to run a radiator, per NHRA rules , but the rule book didn't
    actually specify how practical or effective the radiator had to be. Some
    gas class racers ran actual functioning automotive radiators but some
    others got pretty creative in their attempts at weight saving and built
    super-lightweight and tecnically "rule book legal' - but not really functional
    - rads, using things like automotive air-conditioner condensor cores
    or (other) homemade contraptions, made up of a few bits of alluminum
    tubing welded together tp hold and circulate a minimal amount of water
    and kind of 'resemble' a functional rad! In your case, if you want to run
    an actual functioning rad that would alow the car to be driven though,
    one obsticle could be in mounting a water pump on the engine. I doubt
    a stock Buick V-belt driven waterpump will fit any more, due to the
    blower drive and an electric waterpump, while workable, would probably
    be too 'modern looking ' to look right. One possible solution though -
    since you're still using the marine front cover and mount assembly, you
    could use that to mount a cam driven Jabsco or other brand, marine
    water pump. It wouldn't be as effective as the uch bigger stock,
    V-belt-driven Buick pump, but it should move enough water to allow the
    car to have a functioning cooling system - and would look very slick -
    and not rerquire a belt or interfere with the blower drive! :)
    Mart3406
  16. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    I know the class requires hoods, but I like the fact that the hood is completely missing, it adds to the whole violent theme the car seems to have, I like that it has no bumper in front as well. It's only an exhibition car, I dont plan on competing with it other than running a few nostalgia events. If I ever do add a hood, it will be glass. I'll run a glass rear bumper as well. The Mr. horsepower bird Idea is cool, but I will probably stay away from using existing logos. I'm going to to a cartoon of some sort, but not sure what. It will probably be the whole bird doing a wild burnout or something like that. I picture the face looking crazy and evil at the same time. There will be no radiator in front. If I do anything, it will be in the back somewhere. I may run a cam driven pump as well, not sure. I'll cross that road soon. Keep the ideas comin!
  17. donut29
    donut29
    from canton MI
    Can you get the valve covers off with the motor in the car?
    Can you post some more pix of the intake
  18. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    Yes, the firewall is attached with three dzus fasteners per side. You can get to pretty much everything. I will post some more pics of the intake as soon as I tear it down again.
  19. srosa707
    srosa707
    from Sacramento
    I was just in Santa Rosa on Friday too...
  20. mart3406
    mart3406
    from Canada
    I know it's supposed to technically be a "gasser"
    and maybe this is something a bit (and probably
    a lot) more radical than you want to get into - but
    have you thought about running "Strange Bird" on
    methanol? That would allow you to put some
    overdrive back into to the blower, while still keeping
    the high-compression pistons,.without hurting them.
    Also it would allow the engine to stay cooler and run
    for longer periods of time without a cooling system
    too. It would take a bit of reworking, - mostly drilling
    the jets way oversize and modifying the needles &
    seats for increased flow - but 4GC carbs have been
    modified to work on alky in the past.."Back in the day',
    I knew a guy that did this with a 4GC on a dirt stock
    car as 'cheater' trick for qualifying..If he was running
    at a track where he thought he'd have trouble qualifying
    and/or getting a decent starting position in a typical
    30-plus car feature, he'd skow up with 5 gallons of
    methanal in the tank and his special 4GC alcohol-jetted
    'qualifying carb' on . Once he qualified, he'd fill the tank
    with gasoline and switch to his normal, legal 'gasoline'
    4GC 'race carb' and run in the feature! He eventually
    got caught and banned from a couple of tracks for a
    while , but if worked ....and it was fun while it lasted! :)
    Mat3406
  21. bbc 1957 gasser
    bbc 1957 gasser
    them brown spidys are bad around mi they like to live in wood piles
    glad your ok ..
  22. teddyp
    teddyp
    been reading your thread from the start very cool car like that you used a nailhead and the work looks outstanding for the cartoon how about a falcon like a super hero picking up another gasser in it,s claws ? great car have fun and enjoy it
  23. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I think you need to rename the car "RECLUSE" after you recent attack.
  24. Stone
    Stone
  25. 296moon
    296moon
    from england
    I love this build, youve given me loads of insperation towards mine [​IMG]
  26. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    Jerk. I'm going to delete you on my facebook. pfffftt.
    Ahhhhh! Methanol would be rad, but gas is where its at for this bird.
    Seriously man, almost dying from a tiny little spider bite is humbling. Watch out for them things.
    Thanks! It will probably be just a head, I don't wanna get too crazy with it.
    Super Chicken is badass!
    Not likely. My wife told me to tatto one on my hand too. Totally not happening hahaha. I HATE spiders!
    That makes me stoked to inspire you! Do you have a build thread going for your car?
  27. How you healing up Scotty?
  28. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    I'm good! Only a couple more days on these blasted antibiotics! I still have a huge oozing hole in my hand though. yuck.
  29. Good to hear, you looked terrible in Vegas.
