gasser guys, how long can ladder bar be????
Discussion in 'The Hokey Ass Message Board' started by moparron426, Oct 10, 2009.
  1. swade41
    swade41
    from Buffalo,NY
    With the tunnel ram, not so easy, you have to pull the front carb and linkage to get to the rear. We have about 40 minutes between rounds in this series I run in and the carb change is defiantly needed more so than suspension at this point. The next time out after this one will include the suspension change for sure.
  2. deerchooper
    deerchooper
    after reading alot on the forums about pinion angle, i would have to disagree with your statement. please let me explain my thoughts and tell me if im wrong or tell me why.
    from the great world of forums, building cars and such. most motors are set with a 3-4* down tilt, so ****** is pointing down. to zero out the drive shaft you need 3-4* up on the rear end. with the ladder bar set up ran on that car the pinion should not, no way twist 6-8* up under load.
    am i wrong or am i mixing racing with street driving?
  3. fitzee
    fitzee
    i agree with you..your pinion and tail shaft in your trans should be parallel to each other.
  4. Ebbsspeed
    Ebbsspeed
    S-10 frame, isn't it?:rolleyes:
  5. manyolcars
    manyolcars
    When I set up my ladder bars I talked to an engineer who worked for Chrysler. He told me about 'instant center' and 'moment'. These are things you need to know to do it right. Google is your friend
  6. swade41
    swade41
    from Buffalo,NY
    The norm in racing is setting the pinion angle 2 degrees down from parallel with the trans u-joint. Say the tails shaft of the trans is set at 3 degrees down then you would set the rear pinion at 1 degree up. The additional 2 degrees to become parallel happen when the rear is trying to rotate around while the tires are sticking.
  7. deerchooper
    deerchooper
    cool, thanks for the explaination.
  8. greg32
    greg32
    from Indiana
    The pinion wants to climb the ring gear, in other words, rotate upward. The more down pinion angle you put in it, the harder it hits the tire, and the more it wants to wheelie. This is up to a point, trial and error. Its another fine tuning adjustment, along with instant center length and heigth.Shock settings is a whole subject to itself. And yes, forget about street car angles, regardless of front u joint angle, pinion angle is down a few degrees.
  9. deerchooper
    deerchooper
    thanks again, learn something every day.
  10. had a '41 willys built back in the day. bars went all the way to the trans crossmember. looked a little dumb. just built some for my '40 ford. they are just shy of half the wheel base. yes they look long, but they dont look stupid.
