Gasser - how to raise the front??
Discussion in 'The Hokey Ass Message Board' started by Scumdog, Jan 5, 2011.
  1. Scumdog
    Scumdog
    Hy guys, building a '37 Ford coupe, gasser-style. I want to raise the front about 3".
    It still has the stock I-beam front end - with early disc-brakes.
    I would like advice re getting the main-spring re-arched etc.
    And any problems if it IS raised.
    Oh, running tunnel-rammed 460 and big-input top-loader to 9" rear-end.
  2. lower the front crossmember some how
    i think i remember seeing a 40 something ford that a guy put a mustang II cront crossmember in it and then welded a channel to the bottom of that and bolted the spring on that way
    tk
  3. Mr. Speed
    Mr. Speed
    from USA
    Arching the springs will be a little tougher than most of your other options. If your going for a gasser, just change it to a tubular straight axle and parallel leafes. It'll be worth the effort as far as reliability and looks, too.
  4. HarveyWallbanger
    HarveyWallbanger
    Look up how Bump-Steer is caused.
    Then do everything to avoid that.
    We've got a straight axle under a '55 wagon and 454, and it drives better than any stock A-arm setup.
