GASSER MUST HAVES and cant haves?
Discussion in 'The Hokey Ass Message Board' started by DirtyDave, Aug 4, 2013.
  1. cs39ford
    cs39ford
    image.jpg Nice seats will look good. Mine still has truck bus seats in it from the 60s
    Finn Jensen likes this.
  2. langy
    langy
    I have a nice pair of 63 nova seats if anybody needs, but they are in England
  3. DDDenny
    Are they for RHD or LHD ???
    langy likes this.
  4. langy
    langy
  5. Deuced Up!
    Deuced Up!
    "A blower would be nice." We were sitting around looking at the Austin Project with a Tunnel Ram and I asked Dad if it was missing anything and that is exactly what he said...he was right!
  6. DirtyDave
    DirtyDave
    Cant argue with that!
    mine will have to start as Tunnel Ram.
  7. DirtyDave
    DirtyDave
    What/How did 60's race cars protect/cover their wiring. Today we have heat resistant loom but I ***ume that isn't period correct.
  8. squirrel
    I don't know. But I used friction tape on my modern copy of a 60s race car.
  9. D.N.D.
    D.N.D.
    Hi Dave
    All we had was the black Electricians tape that I used in my 37', and after a while it would get sticky from the adhesive seeping out from the edge's of the tape
  10. langy
    langy
    I would of thought it would of been the standard car loom with modified wiring here and there ?
  11. langy
    langy
    I don't think tunnel rams were used then, I think they came later
    II FUNNY likes this.
  12. langy
    langy
    Don out of interest was many people running inline 6's back in the day ???
  13. DDDenny
    Here, there and everywhere.
    If it was like most cars I've had from the 50's and 60's, there would be enough extra wires going nowhere to wire another car.
  14. rusty1
    rusty1
    2015 events 048.jpg 2015 events 050.jpg speakin of sixes,...here's one I saw last weekend runnin a 292 inline Chevy six...
  15. traffic61
    traffic61
    from Owasso, OK
    Great name. Hahaha
  16. CGkidd
    CGkidd
    Anyone else getting work done on there G***er? I am down hard rolled my ankle bad and am stuck in a air cast. I did get a autogear Muncie case with iron mid plate. I plan on building a M22 with wide ratio gear set with 2.56/1.75/1.36/1.00 gears
  17. DirtyDave
    DirtyDave
    Restoring a kitchen right now so the car waits. I spend a few minutes each day thinking planning scheming. Snuck in a couple shows too. My wife of 20 years (today) is very understanding.
  18. D.N.D.
    D.N.D.
    Hi Langy
    Did not see too many as they were more popular in the 50's, but when the small block chevy showed up it changed the whole engine picture
    Size - weight and cubic inch they were hard to beat, then the speed parts guys went nuts making good parts and you know the story of how they were used in all types of racing
    As a matter of fact my 37' had a GMC 6 in it and ran out on the dry lakes, until I bought it in 60' and started to convert it over to run in B/Gas using the injected 327
    Don
  19. BCCHOPIT
    BCCHOPIT
    Shameless plug!!!!
    Must have!!!!!
    If your running a tubbed front axle in your g***er you Must Have.... Flagged kingpin bosses to present the bosses from popping out when your playing hard!!!!!!
    I have seen 2 pics of cars getting messed up because of junk axles that the king pin bosses are not welded in properly this summer so play safe guys
    Also note it helps to have the king pin set in the tube p***ed the center line of the king pin boss
    https://www.facebook.com/permalink.php?story_fbid=932951813446476&id=602766899798304
    ImageUploadedByH.A.M.B.1438745628.232342.jpg ImageUploadedByH.A.M.B.1438745641.366491.jpg ImageUploadedByH.A.M.B.1438745652.519478.jpg ImageUploadedByH.A.M.B.1438745662.818405.jpg ImageUploadedByH.A.M.B.1438745691.987587.jpg
  20. D.N.D.
    D.N.D.
    Hi Bill
    Your T.I.G. beads are ' Welded Art ' just spot on the money, my buddy Lynn use to build flat track racing frames and his welds were like yours and they would nickel plate those 4130 frames
    Those great beads would just jump off the frame they looked so good hi-lited by the plating
    Its too bad that your axles have to be plated or painted and covering up your nice work !!!
    Don
  21. Dago 88
    Dago 88
    My Nomad I built 15 years ago, still have it but it is back on a standard frame. \'56 nomad.jpg
    55 Ford Gasser likes this.
  22. Dago 88
    Dago 88
    55 Ford Gasser and enloe like this.
  23. DirtyDave
    DirtyDave
    BCCHOPIT with welds like that you can say anything. WOW those are nice!
    My 39 will be employing the stock front axle. While we are on the subject I have never been a fan of tube straight/drop axles. Maybe someone could educate me on their history?
  24. They are alot lighter than an I beam axle. It was a natural progression to going faster.
  25. D.N.D.
    D.N.D.
    Plus building a g***er in 62' having a tube front axle had a big ' Cool Factor ' in your car
    Plus mine had some drop to it too for more Cool
  26. BCCHOPIT
    BCCHOPIT
    Dave....
    I like stock axles. Lots of times it harder to work around the stock spring pads locations and most have a drop. The tube just give you more freedom to locate your springs -shocks - pan hard bar and you can make them any size you want.
    If you need stronger you can use lager tube and thicker wall thickness
    My largest axle to date is 21/2 OD. .312 wall moly...
  27. DirtyDave
    DirtyDave
    If my car does that I will need a cleanup on the interior!
    While we are sharing pics I will post these from last week at Colonial Beach VA. (I didn't take these).
  28. BCCHOPIT
    BCCHOPIT
    That's Rick awesome guy he also runs one of my axles. I built him one of my tubed I-beam axle I think 3 years ago might be 4 now.... ImageUploadedByH.A.M.B.1438957802.994653.jpg
    2" 1/4 wall moly. With a 1/2 flat bar machined to fit then plug welded top and bottom
    Rick plays very hard!!!!
    ImageUploadedByH.A.M.B.1438957929.358848.jpg ImageUploadedByH.A.M.B.1438957946.040114.jpg
  29. DirtyDave
    DirtyDave
    My 39 Hudson axle/frame where I purchased it in 2012
    BCCHOPIT likes this.
  30. DirtyDave
    DirtyDave
    Rick does play VERY hard! Over & over & over!
