GASSER MUST HAVES and cant haves?
Discussion in 'The Hokey Ass Message Board' started by DirtyDave, Aug 4, 2013.
  1. langy
    langy
    I've found that's the only way it stays on even on stainless
  2. DirtyDave
    DirtyDave
    Good tip on header paint break-in.
    I am looking at the raw H8033 Patriots
  3. Larry T
    Larry T
    I usually bake anything that I paint with high heat paint in an over at about 300 degrees for a couple of hours and then just turn the oven off and let it slowly cool. Works GREAT on Harley cylinders.
    But headers don't fit in the over, so I hang them over a shop heater (collector down) for a couple of hours to bake the paint. So far, it seems to work pretty well----but not as well as ceramic coating.
  4. Augie Delgado has Embee's white stuff on the headers in his silver Jackson injected '66 Nova, but says he has to redo them every other year.?
  5. D.N.D.
    D.N.D.
    When the VHT Rattle can paint came out they asked you to take your torch and kinda pre bake it on, I used the black on my dirt bike pipes and it was very good
    Now you have all the hi tech coatings to pic from for a much better finish that lasts longer too
    G Don
  6. hotroddon
    hotroddon
    With how much Augie drives that thing, it wouldn't surprise me if they don't look a little "worn" after each two year stint. ;)
  7. Baron
    Baron
    If you don't mind black, I have been using John Deere muffler paint for years. First time I used it was on my Harley exhaust pipes and mufflers. Used it on a number of headers over the years with the same result.
  8. Ha Ha, good point!
  9. 1971BB427
    1971BB427
    from Oregon
    I used VHT 1500 degree Flameproof header paint on my Austin Steve. It's been on there over 3 years now and still looks good, other than stains from road debris. No flaking or peeling, with driving in all kinds of weather.
  10. langy
    langy
    Val the one we get here is listed as VHT 1200 degrees, not as good maybe ???
  11. langy
    langy
    The mild steel headers on Sue's RP got the aluminium spray treatment and then white VHT, here they are after 9 years of use, pretty good I reckon
  12. rustang
    rustang
    +1 I've used this on some of my sled expansion chambers, and on the headers and it works probably better than anything out there at the moment.
    Tom
  13. 1971BB427
    1971BB427
    from Oregon
    Steve, I just looked at my can of VHT, and it actually says it's rated 1300-2000 degrees. Not sure how it has a range that wide, but it does seem to hold better than the old stuff we used.
  14. 1971BB427
    1971BB427
    from Oregon
  15. Brad54
    Brad54
    from Atl Ga
  16. rfraze
    rfraze
    Why would a nose-high g***er style car be built with a dropped axle? "We had it" may not be a good enough answer.
  17. DirtyDave
    DirtyDave
  18. II FUNNY
    II FUNNY
    I agree, it looks like a funny g***er to me.The article says something about wheelbase changes from year to year, and I'm sure that Don Long took that advantage plus whatever he thought would sneak by.
    MELTDOWN DRAGS
    JULY 19-20 2014
  19. 1971BB427
    1971BB427
    from Oregon
    Kidding, right? I can tell you from experience that far more gas cl*** cars got dropped axles than those with straight axles! And many of those were donor axles from other cars, trucks, or vans. I've put one straight tube axle in a****st the 8-10 axles I've installed for myself or others. That one straight axle is in my Austin, and I did it because I needed to have a very narrow axle and didn't want to cut down a dropped I beam axle.
    And I just finished another install today on a friend's car; a dropped I beam axle.
  20. Baron
    Baron
    I have a 4 inch dropped axle in my 55,becasue I did not want it to be too nose-high.
  21. Lytles Garage
    Lytles Garage
    They just look Cooler? Chris
  22. D.N.D.
    D.N.D.
    I never liked the looks of a straight tube one so I asked the fab guy put a slight drop in it, just kinda fit the look of the 37' too
    And as I recall I took out 3 leafs on each side because of the total lighter weight of the car, and it sat level like I wanted and would raise up off the line and settle back down half way down the track
    G Don
  23. Brad54
    Brad54
    from Atl Ga
  24. Brad54
    Brad54
    from Atl Ga
  25. langy
    langy
    Because a straight axle puts them up real high, too high in my humble opinion.
  26. D.N.D.
    D.N.D.
    Hi Brad
    In the early 60's the only trans that would hold up in the blown g***ers was the Hydro's
    Bob - Don and Mort at B & M designed & built the quarter eliptic rear suspension for the guys that used their hydro's trying to get a better bite with those hard tires
    Me and my buds would stop by at their first shop on the bend of Sherman Way in Van Nuys and see whose g***er was in the shop in 1960 - 61
    Cool place to see the latest happenings going on when it all started, back then the 6-71 blowers were just getting to be the deal on the g***ers and dragsters too
    Glad I was there to see it all
    G Don
  27. 1971BB427
    1971BB427
    from Oregon
    This brings up a question I've pondered for years. I remember when Mallicoat Bros. and Ohio George both brought out cars with turbocharged engines. Both cars dominated the Gas cl***, and instead of embracing the turbo engines NHRA banned them. I've always wondered why they took this stand to ban new technology, instead of letting others also develop turbo engines and join in or catch up.
    If NHRA had taken the same path when superchargers had first come into use, they'd probably just now be getting popular.
  28. black 62
    black 62
    from arkansas
    could have been because turbo cars sound so whooshie compared to a blower car...
  29. 1971BB427
    1971BB427
    from Oregon
    Yeah, I'm sure NHRA banned them for noise.
  30. willys41
    willys41
    Its was new technology.. they knew nothing about it.. and they were afraid of that fact. I wonder where top fuel would be at if they had allowed it.
