GASSER MUST HAVES and cant haves?
Discussion in 'The Hokey Ass Message Board' started by DirtyDave, Aug 4, 2013.
  1. todztoyz
    todztoyz
    There's a nice g***er project on the local cl. Lots of good stuff, 4 pot injection on a blower, nice paint, nice wheels, but the stance is total 4x4! I emailed him and said I liked the car but no g***er ever went down a track looking like that. (polite as I could) He told me that's how he remembers them. He already built and sold one like it. I musta missed something.
  2. D.N.D.
    D.N.D.
    Hi Tod
    No you did not miss a thing, as I hate those jacked up g***ers too plus being very un-safe they are UGLY and not in the spirit of the g***er cars from when I raced
    G Don
  3. swade41
    swade41
    from Buffalo,NY
    I just want to say that I just got my Speedway straight axle kit and the combined shipping weight was 152.8 lbs. That is all........
  4. squirrel
    2" 1/4" wall axle....is anyone making a lighter one? and how about some monoleaf springs?
  5. 1971BB427
    1971BB427
    from Oregon
    From what I found out on mine; the Speedway is thicker than their advertised 1/4" wall. I had to narrow mine in my Austin, and was surprised when I cut the tube and it measured well over 1/4" wall thickness.
    Unless they've changed in the last few years since I got mine.
  6. Larry T
    Larry T
    Mark Williams still makes them. Chromemoly and I think .188 wall. Don't hold me to the wall thickness though.
  7. hotroddon
    hotroddon
    MW makes his from 1 5/8" Chomoly .188" wall ;)
  8. Does Speedway make an axle narrow enough to fit under an Anglia? I'm not looking to make it nose high, more of a late 60's early 70's look.
  9. Marty Strode
    Marty Strode
    BCCHOPIT here on the HAMB, will custom build you an axle, any width you need.
  10. Marty Strode
    Marty Strode
    We used a Speedway axle kit under this one, BTW it is on the cover of Street Rodder this month. It was built in the spirit of the mid 60's, with some modern touches like front disc brakes, and an 8.50 cert cage, and street legal as well.
  11. swade41
    swade41
    from Buffalo,NY
    It says custom length axles to order in their adverti*****t, but only ford/chevy king pin size.
  12. 1971BB427
    1971BB427
    from Oregon
    Not that I know of. I ordered the narrowest axle they had and then cut it down to fit my Austin A10. Same similar size as your Anglia. I cut mine down to around 39" kingpin to kingpin.
    Edit-I see they do now offer custom widths.
  13. Larry T
    Larry T
    That's what I was thinking. One of their 3" drop/40" king pin center axles looks like it will be real close to what I need for my Anglia.
  14. Baron
    Baron
    My next axle will be chrome-moly. I'll have Tinny's Hot Rod Shop make my next one. I spoke with him when I was doing my 55, but I needed a dropped axle and he only does straight axles.
    "he did Shaky Puddin's axle"
    Here is an old thread from 2009.
    http://www.jalopyjournal.com/forum/showthread.php?t=330536
  15. Yeah, 38 to 40" looks to be about right. So, what spindles can be used on these? I don't care if it's 5x4-1/2 or 5x 4-3/4 at this point.
  16. Larry T
    Larry T
    That's the right length for an Anglia axle if you use the Anglia style spindles. If you use Ford spindles, the axle needs to be quite a bit narrower.
  17. Baron
    Baron
    I prefer Ford spindles over Chevy spindles. Better choice of steering arms, etc. Most hubs can be ordered with any bolt circle you want (or if using early hubs, can be re-drilled to the desired pattern).
  18. 1971BB427
    1971BB427
    from Oregon
    I went with Ford spindles, but Chevy bolt pattern. They will add 8" to the wheel to wheel width.
  19. powrshftr
    powrshftr
    What was your reason for going with the Chevy bolt pattern?Im guessing it was either the rotors you wanted to use,or you had a nice set of slots already in a Chevy bolt pattern...?
    Scott
  20. 1971BB427
    1971BB427
    from Oregon
    Several reasons. I had a Pontiac axle already narrowed for my Austin, and it was 5x4.75" pattern, plus a pair of ET slots for the car that were also Chevy pattern, plus tons of Chevy pattern wheels, etc. around.
    Went 5x4.5 on the Falcon all around, because of the Explorer 8.8 rear, and the Econoline 5x4.5 straight axle. I try to keep life simple.
  21. powrshftr
    powrshftr
    I figured it was something like that.
    Scott
  22. R. Seghi
    R. Seghi
    Radiused wheelwells 'nuff said.
  23. swade41
    swade41
    from Buffalo,NY
  24. micky69
    micky69
    from Ohio
    Fast times did my axle also. Pete does great work.
  25. langy
    langy
    And very nice it is too !!!
  26. Lytles Garage
    Lytles Garage
    Car looks *****IN Marty !! COOL you got the COVER !!! Chris
  27. Tim Irwin
    Tim Irwin
    I'm currently building an Anglia. I'm using early Ford spindles with Wilwood brakes. Ill go out and measure all of it for you. I built my own axle it's pretty narrow, don't remember the actual dimension.
  28. Larry T
    Larry T
  29. Tim Irwin
    Tim Irwin
    My front clip measures 54 1/2" wide. My wheel/hub/spindle ***y. measures 8 1/2" from the outside of the tire to the king pin CL. I made my axle 37" wide. Total overall width is 54".I'm using Wilwood brakes and American Rebel 4" front wheels.
  30. swade41
    swade41
    from Buffalo,NY
    Speedway has a 54 inch hub to hub axle kit, I ordered the 56 1/2 for my Henry j, it's a 48 inch king pin measurement. Which is the same as my t-bucket 4 inch drop tube, outside tread width on that with 5.60 tires is 60 inches. I measured my J and with it's skinny tires it also had a 60 inch tread width.
