Gasser owners! what rear ends and engines are you running?
Discussion in 'The Hokey Ass Message Board' started by gasser52, Feb 6, 2007.
  1. gasser52
    gasser52
    What kind of engines and rear ends are you running in your g***er? whats a good combo? Pics if you feel like it.
  2. stray dodge 46
    stray dodge 46
    I just got a 51 chev g***er project but I plan on running a small block and a 4 speed.I will probably run a 9 inch because I already have it.Dont forget the fenderwell headers.
  3. Yo Baby
    Yo Baby
    Presently a a low comp. SBC and a glide with a 57 Poncho rear.
    Soon to be a low comp. SBC and Doug Nash 5 speed with a 57 Poncho rear.
  4. Chevy Gasser
    Chevy Gasser
    How about '57 pontiac (Dana) with 5:56 gears! It was set up this way in the late 60's to run the 1/8th. I'm sorry to say I don't have any time slips.
  5. Chevy Gasser
    Chevy Gasser
    Engine is a 327 +.060" =337. Isky cam mechanical Hilborn fuel injection, unprimed. Run only one day in the last 30 years. I hope to get the driveshaft back from the chrome platers this week. Looking forward to driving it for the first time in a long time this spring.
  6. gasser52
    gasser52
    yeah i hear he 57 pontiacs are the way to go rear end wise, i currently have a 57 chevy car rear in it, and plan on running a 327 or 283 possibly
  7. 5w32
    5w32
    no doubt , 57-64 olds or poncho!
  8. Brad54
    Brad54
    from Atl Ga
    482-inch 409 Chevy.
    Slick-shift Hemi 4spd "crash box" built by Liberty gear
    Vertical Gate inline shifter
    Mopar 8 3/4 rear
    "Leaf Link" rear suspension: Floater axle perches, upper bar links like a 4-link, front half of the leaf springs clamped to make them solid (like the bottom bars on a 4-link), no clamps on the back half of the springs so they still move.
    All positions are in 1-inch increments: Housing perch on leaf spring mounts: 3 positions; front leaf spring eye to ch***is: 2 positions; front of upper link where it connects to ch***is: 3 positions; upper link on housing: 2 positions. For a total of 36 different positions to triangulate the rear suspension to tune hook and instant center when it launches.
    I chose the 8 3/4 rear because they're damn near bullet proof, very affordable, are all 30-splines, and are stronger than a similarly priced/equiped 9-inch. The 9-inch, with a lot of aftermarket parts and price, can be built stonger than a stock 8 3/4, but by that time, it's cheaper to go with a Dana 60.
    -Brad
  9. BBF 8-71 huffer
    toploader
    9in
    53 f100
    tk
  10. I'm runnin a 350 sbc with turbo 350 and stock rear-end in my '56, but will be putting a 4-spd and Olds rear-end in when the funds become available. My buddy is running a 409/4-spd with a Ford 9 in.
  11. Chevy Gasser
    Chevy Gasser
    If you go with the Pontiac rearend, just follow it forward through the driveshaft, pontiac ujoints are heavier also. That's a good thing. However, when you get to the transmission you may run into problems. If you go with the late 60's fine splined talishaft (Muncie) you shouldn't have a problem finding them. I am going with the early 60's 16 splined Borg Warner style, that yoke is hard to find. I'm looking for one right now. anybody have one?
  12. Larry T
    Larry T
    The last time I ran it, in the 80's, 336 cu. in. Chevy, M-20 4 speed, and 5.38 Pontiac rearend. It ran 7.50's in the 1/8th (L.A. Dragway) and 11.40's in the 1/4 (Green Valley).
    If it ever runs again (don't laugh Chuck), it'll have a 355 Chevy, old Nash 5 speed and I'm really leaning toward a 12 bolt Chevy rearend.
    The reasons I'm thinking about the 12 bolt are that it's lighter, takes less hp to turn, easy to get parts for. If you want to run an early Pont/Olds hard, you might think about replacing the side carrier caps with Mark Williams parts.
    Larry T
  13. Don Moyer
    Don Moyer
    Olds rear in mine too, amc mill........
  14. Yo Baby
    Yo Baby
    I have a freind up here who has run as quick as 8 flat 1/4 with the Pon. rear the only mod made was a backbrace with a bolt going through from the outside to the left rear cap to preload it and solved the breaking cap problem
  15. 55project
    55project
    from Phila. Pa.
    I'm getting ready to start on my second 62 ChevyII axle car, g***er, and i have a 57 olds/pont rear for it. I brought a 68 Camaro drag car just for the rearend, and sold the rest. The rear has 5:13's, spool, and Summers Brothers axles in it. I'm going to go with 4:56's and a posi for the street.
    Oh and i'm running a do up 350 right now but i have a 70 454 to put into it when i get the time.
  16. when I ran a g***er, I used a Dana 60, spooled with 5.88 gears, hemi 4 speed with straight cut gears and a very high winding 350 sbc. Side stepped the clutch at 5 grand, hung on, and shifted at about 8 grand.
  17. Mike
    Mike
    My '57 Chevy 150 has a built 327 (dual quads, hot cam, solid lifters, roller rockers, high compression aluminum heads, long tube headers), Muncie 4 speed and a Ford 9" rear axle with 4.11 gears mounted on parallel leafs with beefy, fixed traction bars. Below is a link to a picture of my heap on Don's Hot Rod Page.
    http://www.donshotrodpage.net/CHRR/pages/XPA060134_JPG.htm
  18. Brad54
    Brad54
    from Atl Ga
    It's not totally traditional, but if you're thinking of running a 12-bolt, think about a Ford 8.8. They're MUCH cheaper to build than a 12-bolt, and common as dirt (under everything from Mustangs to Lincolns to Explorers to trucks to Crown Vics). Take one apart, and it looks like the Ford engineers reverse-engineered a 12-bolt; same size bearings, gears are the same...one has two more ring gear bolts than the other, but they're slightly smaller diameter, I forget which is which. The Mustang guys have been running them in very, very fast and powerful cars for a long time. They have the advantages you listed too--lighter, less parasitic HP loss.
    Plus, you can frequently find them with disc brakes.
    -Brad
  19. Fossil
    Fossil
    I run a 350 and a TH/350 to a Mopar 8 3/4" rear. Not too exotic, but I race the car...and sooner or later I'll blow it up. I can get back in the game pretty cheap.
  20. ROADKILLER
    ROADKILLER
    from IL
    Does anyone know how wide those olds/poncho rears are? Building 61 falcon g***er.
  21. TINGLER
    TINGLER
    My car has a 289 with a Ford 8" rear. :eek:
    I've already got a shortened 9" on the shelf waiting the day when I tear the car back down and really soup it up.
    Future plans are for a hot SBF. Possibly a stroker. A toploader 4 speed and a 9" rear.
  22. shemp
    shemp
    Alliance Vendor
    My '55 Chevy project has a 301 running a T-10. Olds rear with 5.13 gears. I've taken it apart to build a new front frame stub for it, so it's not in running condition at the moment.
  23. Blown 61
    Blown 61
    I wouldn't be so sure about that 8.75, on the moparts board lots of guys breaking them. I guess a mark williams billet cap and a back brace help but they are still breaking them. Just a heads up.
  24. Von Hartmann
    Von Hartmann
    My henry J has a 68 chevelle large journal 327 bored .020 over crossram with 390 holleys. Turbo 400. Lincoln versallies(spelling?) 9in in the rear. It's a disk brake rear and it's already narrow stock. Has a built 3rd member with 31 spline moser axels, It's all new and I think it should work well, however I've heard stories of the em. brake locking up on them.
  25. Boones
    Boones
    from Kent, Wa
    my Dads 51 chevy g***er project is running a 600 + hp sbc, Olds rear with 4:88 posi and a 6sp
  26. gasshole
    gasshole
    from new jersey
    I just run a boring old 355cu SBC w/hydrolic flat tappet,10psi boost ,dana 60 with 4.11s and a glide w/brake (after 4 wide ratio muncies) its good for mid tens. The same combo went 9.40s in my 76 chevette,that was a fun ride:D
  27. My 57 Belair g***er wannabe sports a 454 BBC along with a Borg-Warner Super T-10 connected to a Ford nine inch.Going to buy a 3:50 ratio Trac-Loc to keep it drivable.
  28. ProEnfo
    ProEnfo
    from Motown
    Not me..:eek: .....now git'er done..:D
    CC
  29. Gasserman
    Gasserman
    from Tulsa OK
    351 Cleveland Ford with Hilborn injectors, Doug Nash 5 speed inline Long shifter, 9" with 4.86 Strange spool and axles in a `60 straight axle Falcon
  30. flamedabone
    flamedabone
    Pontiac doesn't just make rear ends....
    Here is the old Henry J motor...
    Here's the Henry J...
    -Abone.
