Event Coverage Gasser Reunion 2013, Changes more Hamb Friendly!
Discussion in 'The Hokey Ass Message Board' started by Don Moyer, Dec 20, 2012.
  1. Don Moyer
    Don Moyer
    News to me! What did you hear, and where did you hear it?
  2. swade41
    swade41
    from Buffalo,NY
    I heard the same thing but I was with those guys...lol (It was not from GRS in any way)
  3. Don Moyer
    Don Moyer
    Thank you! Larry puts on a great show and the coverage is well deserved! Congrats to Hot Rod Jen also for the pics!
    I would also be lying if I said I thought I would ever have a picture of any of my cars in the Rodders Journal! Thank you to them for picking it as one of the examples for a great show!
  4. Don Moyer
    Don Moyer
    I covered the bases at this end and there is nothing to it....
  5. DH9185
    DH9185
    Are all cars required to p*** NHRA inspection regarsless of index? Run 12's, street driven but battery is behind the p***enger seat right now and I have no aluminum rear firewall with trunk mounted tank. Dave
  6. Don Moyer
    Don Moyer
    Dave, you will need to change that to race. For the 1/8 mile street race the battery needs to be mounted securely.
    Don
  7. chevy3755
    chevy3755
    Hi Don......dont let all the acolades change your hat size with the Rebel Reaper.............
  8. DH9185
    DH9185
    Don, the battery's in a vented Moroso box bolted to the floor. Have a now illegal spring bar 10-point cage, has battery shutoff rear. No working headlights (guts are gone) which disqualifies me from joining at least one g***er group. Looks like I'll need to get a huffer before I can break into the slowest g***er index, not sure what that is. I'm sure I'd run into similar issues at Thompson so I'll probably remain a spectator for some time before I put 5 grand together for a 6-71 and new pistons. Sure sounds like fun racing, hope to see some now that I've moved back to Ohio. Hope all goes well for you now that you're the new BMFIC, has to be painful at times trying to satisfy everybody. Dave
  9. Don Moyer
    Don Moyer
    You have no idea....as far as the cage, I am pretty sure nhra only requires the cage if your faster than 12 seconds. I don't know what the term "spring bar" is? As far as working headlights, not a problem.
  10. DH9185
    DH9185
    Entry is via old school spring loaded bar that's pulled to separate the bar for entry, then returns to connection when swung shut. What's the slowest gas cl***? Should run faster this year with new engine and going to a 2x4 tunnel setup, but don't know if I'll get her into the 11's. Hope so, had some issues with the old motor, still ran hi 12's. Is this battery a problem? It's NHRA accepted for hatchbacks I think.
  11. swade41
    swade41
    from Buffalo,NY
    I run the same battery box in my Henry J right over the rear with no other par***ion between it and driver. It is acceptable according to the NHRA rule book and has p***ed IHRA tech.
  12. Don Moyer
    Don Moyer
    8.1 Battery Re-location
    All batteries must be securely mounted and may not be relocated into the driver or p***enger compartments. Rear firewall of .024-inch (.6 mm) steel or .032-inch (.8 mm) aluminum (including package tray) required when battery is re-located in trunk. In lieu of rear firewall, battery may be located in a sealed .024-inch (.6 mm) or .032-inch (.8 mm) aluminum, or FIA accepted poly box. If sealed box is used in lieu of rear firewall, box may not be used to secure battery, and must be vented outside of body. Strapping tape prohibited. A maximum of two batteries, or 150 pounds (68 kg) combined maximum weight (unless otherwise specified in Cl*** Requirements) is permitted. Metal battery hold-down straps mandatory. Hold-down bolts must be minimum 3/8-inch (9.53 mm) if battery is relocated from stock and other than stock hold-downs are used ("J" hooks prohibited or must have open end welded shut.).
    I found this on the net, would think it is applicable. I also believe you need a shut off switch on the back of the car labeled on/off.
  13. Don Moyer
    Don Moyer
    The G***er Magazine "G***er Reunion" for this year has been canceled by Beaver Springs Dragway. It is very unfortunate that I had to first learn of this here on the HAMB via rumors. Last week when the rumor started on this thread I contacted the other magazine officials to see if there was any validity to this rumor. I was ***ured that nothing was from our end. I then contacted Beaver Bob and asked the same thing. He was hesitant and secretive. There was smoke. He then asked me to run "his race". Now the fire is a blaze! When I declined for obvious reasons, he was worried that our relationship would be compromised. I ***ured him that it was! He then asked to give him a couple days to put a sharper pencil to the program to see how he could make it work. He also asked that we keep our conversation private. I did. After 5 days I called his cell and left a message to have him contact me. He did not return my call all weekend. I left another message on Monday and also reached out to him on another social network he was active on yesterday, still no return call...Today he answered his phone when I called.
    Beaver Bob "in the interest of his local g***ers" is going to have his own g***er race. He informed me that he liked some of my idea's and was going to incorporate them into his event! He has already contacted Bruce Larson to be his Grand Marshall! He has not updated his web site for the Dragway as of this posting, however, the Cruizn'Times web site here in Cleveland Ohio already has the name of the event and schedule listed on their web site.
    June 8-9-10 (2013) ~ Pa. G***er Nationals, Beaver Springs Dragway, "Beaver Bob" says, "all g***ers welcome,", front engine dragsters, altereds, Cruisin' Times will be there shooting a feature story, visit their website: Beaver Spring Dragway for more info. or call the track:(570) 658-9601
    I guess he was too busy to have the decency to call me to inform us, the magazine of his late decision.
    I am a very open person and live by the ideal to treat people how I would like to be treated. That being said I will not participate in the PA G***er Nationals nor any other event at Beaver Springs Dragway.
    As far as the Reunion this year, this late in the game as far as schedules etc, well, it is not looking good.
    We need a venue.
    I am looking at possibilities and would like input on racing 1/8 mile vs. 1/4. Thanks!
  14. micky69
    micky69
    from Ohio
    It ****s Don, for several reasons. Going to be hard to find a replacement this late. Good luck.
  15. ME.GASSER
    ME.GASSER
    Wow. Don i am very sorry to hear this. I'm sorry that you had to hear about it that way.
    Wanda
  16. benji2714
    benji2714
    That's to bad Don! You had allot of work in this. Once again MONEY rears it's evil head, I guess. My 2 cents.
  17. alkycoupe
    alkycoupe
    I will never set foot at his track again, never cared for him last year, thought i'd give it another try this year because of all Don's efforts but $#@$@$@ him!
  18. alkycoupe
    alkycoupe
    Milan, Dragway 42, there are a lot of other tracks eight mile or quarter makes no difference to me.
  19. richie rebel
    richie rebel
    how about the reunion at thompson this year,still on ???
  20. micky69
    micky69
    from Ohio
    Thompson is on, its their own deal. The problem with Beaver is too many others chirping in his ear about their deals and not letting it be "one" group effort and run as a whole. Like the GRS does for Empire, running under one en***y rule would be the way it should be run for a "Nationals" style event.
  21. benji2714
    benji2714
    Yes. That's still there Friday May 31 Sat June 1st
  22. richie rebel
    richie rebel
    thanks guys,ya'all going to be there
  23. alkycoupe
    alkycoupe
    Wouldn't miss Thompson.
  24. DH9185
    DH9185
    Per Micky, you might try 42, they may be glad to get it, maybe later in the year? Very near me so I'd be glad to help if you need some. Planning on going there for Rock n Race this year but won't race at the reunion so I'd have more time than the racers. Dave
  25. ags41dave
    ags41dave
    from midwest
    Don;are you in the choppers show this year?if so,we'll discuss some ideas there.Dave
  26. Junior Stock
    Junior Stock
    Or all the bickering between the differant groups.
  27. swade41
    swade41
    from Buffalo,NY
    Sorry Don, to bad they couldn't be up front with you about what was going on instead of being blind sided like that.
    The G***er Racing Series will welcome all you guys at The Gold Cup August 17-18th http://www.g***erracingseries.com/#!__schedule-rules
    come out and have a great time !
  28. Class Reunion
    Class Reunion
    from N.E. PA
    Wow, Beaver Bob is a snake? :eek: Next I'll here the Easter Bunny is a fake.
    Gregg
  29. LZ
    LZ
    Sorry Don:
    Just don't have words. But like Phil said stop by Empire anytime, just enjoy your car.:)
    Luke
  30. NHRANUT
    NHRANUT
    from Western PA
    I'll be there Richie. Won't see you at Wexford anymore, so you have to go to TRP.:)
