Technical gasser steering pitman arm help.
Discussion in 'The Hokey Ass Message Board' started by Kona Cruisers, May 21, 2024.
  1. Kona Cruisers
    Kona Cruisers
    He guys.
    any ideas on a drop pitman arm the fits a Saginaw 525?
    has the 1 1/8 selector shaft. I know most of the 4x4 ones have an 1 1/4 selector shaft…
    thanks for your input
  2. X-cpe
    X-cpe
    Heat, a press, 2 pieces of angle welded side by side (open side down), and a piece of round bar between the press and Pitman arm. If drag link/center link is above the Pitman arm, ream it halfway to drop the drag link/center link below the Pitman arm. Of course you're going the opposite direction.
