Technical Gasser suggestions
Discussion in 'Traditional Hot Rods' started by popper183, Dec 16, 2016.
  1. popper183
    popper183
    Recently purchased a 49 Chevy business coupe I want to turn into a g***er. I think I'm leaning towards the Highboy look. I have been looking at the Speedway axle kits. Any pro's or con's on these? Heard some talk about the shorter length springs not handling as well. Any imput would be appreciated.
    popper
    John Lynch
  2. old sparks
    old sparks
    Short springs harder ride an more chance of bump steer. If you screw up the pitman arm angle, lots of bumpsteer on any spring. the deciding factor is axle centerline forward
  3. old sparks
    old sparks
    Sorry screwed that up stiffer springs less chance of bumpsteer
  4. hotroddon
    hotroddon
    G***er and Hi Boy are two very different things .........
    mad mikey, wbrw32 and tfeverfred like this.
  5. popper183
    popper183
    Really, I'm learning something new already. Ok I searched Hiboy and see the difference. I guess I was referring to where the whole g***er is up in the air not just the raked front end.
    popper
    John Lynch
  6. DDDenny
    Why not buck the trend and not go for that "nosebleed" look in the front.
    Nobody says they have to look that way, many cars "of the day" were level.
  7. High5
    High5
    Here's my '49 Chevy coupe modified in 1964. The front suspension crossmember was unbolted from the frame and 4" riser blocks slid between them. You got the g***er look without sacrificing the ride. Just a thought.
  8. D.N.D.
    D.N.D.
    G***ers were from your streeter that got a little too speedy for the street
    Street cars were always setting level right off of the showroom floor
    The higher it is the more un-safe it is at speed when the air gets under it and they start to fly
    I did not want to fly in mine and that is why it sat level, plus they just look better !!
  9. X38
    X38
    People these days get confused between 70's street freaks (street machine fad):
    And 1960's gas cl*** race cars:
  10. manyolcars
    manyolcars
    x38 is right about the term streetfreak
    rudestude and OahuEli like this.
  11. southcross2631
    southcross2631
    Having built a 55 Chevy Highboy back in the late 60's . Chevy van front axle and blocks in the back
    so I didn't have to radius the rear fenderwells. Then having to deal with the way it drove and trying to
    drive it to work everyday in Miami was not one of my better ideas. Ended up radiusing the rear wheel wells with Nomad fenderwells cut out of a Nomad that was in the junk yard and lowering it back down. Then it drove about like a 55 Chevy pickup. Had a 409 4 speed in it ,but Sunoco 260 was 31 cents a gallon so the 10 mpg was no big deal.
    A friend has a 53 Chevy with a spaced down crossmember like the one mentioned previously and he drives his everywhere.
    loudbang and OahuEli like this.
  12. popper183
    popper183
    Nice looking ride!
    popper
    John Lynch
  13. popper183
    popper183
    I've seen where this can be done. I really like the look of the straight axle though. Is the handling and ride of the straight axle car that much worse? I think somebody mentioned longer springs help the ride but you are limited due to axle positioning. And I realize that linkage geometry is important as old sparks stated.
    popper
    John Lynch
  14. southcross2631
    southcross2631
    For a lot of street driving and long distance running a U Weld it sway bar kit and power steering makes them handle fairly decent. Adapted a GM power steering box and added the sway bar on a 64 F100
    put a slide in camper in the bed and drove all over the mountains . A well set up straight axle car will
    give you many miles of fun driving. A poorly set up straight axle will make you wonder why
    you did it in the first place.
  15. High5
    High5
    Every straight axle car I either drove or rode in would "porpoise" something awful at every irregular surface to the road or after hitting a chuck hole. Back then you were more tolerant of things like ride quality and would disregard it. But as I have gotten older, I like to climb out of a car and not have to stretch to work out the kinks. I agree with southcross2631 that done right and you will be fine. My '55 Chevy has a van axle under it and the ride is pretty decent (due in part to an alignment shop installing it years ago). But I loved the ride to the '49 Chevy.
  16. Jalopy Joker
    Jalopy Joker
    just going for the G***er look? what motor will you be running?
  17. mad mikey
    mad mikey
    Yea! What engine, trans,rear? Have you decided on wheels?
  18. BLACK STUDE
    BLACK STUDE
    Enough grunt and you can have both looks. DSC_0803.JPG IMG_20160407_033637.jpg
  19. OahuEli
    OahuEli
    from Hawaii
    Post a pic of your car and I'll photoshop it with your ideas. Btw, a 409 and M-22 Rockcrusher would make your car real fun to drive, plus add a cool air to it.
  20. OahuEli
    OahuEli
    from Hawaii
    I rode in the back seat of a car real similar to this in the mid '70s. 289 tri power, 4 speed w 4.88s. I can still taste the vinyl from when the owner lit it up on cold tires and we did a 360 right in the middle of town. It was one ill handling beast but when he could keep it straight it was fast as hell.
  21. slowmotion
    slowmotion
    Lot of good suggestions already. I'll add that a 2" I-beam might be just right getting the front up a little if you decide not to go the axle route. One other thing, these cars in the style you're after scream for rear wheel well radius IMO. Goes so well with the rounded lines of the car, shoulda been that way from the factory IMO!:D
  22. DDDenny
    Around 1970 a high school mate built a 50 (ish) Chevy coupe with IIRC a truck beam axle.
    This had a 327/365 horse engine, yep, a real one. It was paired with a B&M prepped 4 speed hydro. This thing was scarrry but damn did it haul ***.
  23. popper183
    popper183
    Slowmotion, the bottom picture is the look I like but the front a little bit higher and then bring the back end up a little to level it out.
    Mad Mikey, As far as drive train I have a 533 cu. in BBC that we took out of my wifes rear engine dragster about 3 years ago that I thought I might freshen up and change the pistons to lower the comp ratio to something streetable. I also have a fresh turbo 400 with a trans brake I figured I would use. And for the rear end I'm kind of partial to 9" fords. Wheels will be something from Rocket is what I'm thinking.
    OahuEli, Waiting for the weather to clear so I can get it home then I'll get some pictures. We get snow here, Lol!
    Thanks everybody for your suggestions, your comments and help are appreciated. I have a 64 Nova that I drag race, and a 61 Bubble top that I built for street/strip but this is the first project of this type of my undertaking. Just want to build something not to fancy, flat black, period correct in looks and simple. Just a fun type old school appearing hotrod.
    popper
    John Lynch
    loudbang and slowmotion like this.
  24. popper183
    popper183
  25. AHotRod
    AHotRod
    DON'T put a Speedway straight axle under it, it's not tough enough for that size of car in my opinion.
    If your dead set on building it with a straight axle, get one from WAC.
    Cut open the rear fenders and let the tires hang out.
    If you want to make it look right, see what Quain Stott and the guys do, go here: http://www.southeastg***ers.com/
    loudbang, 117harv and mad mikey like this.
  26. DDDenny
    John, I'm sure you are hip to this considering your drag racing involvement.
    Nine inch Ford would be the rearend of choice for a modern high horse drive train but to appear period correct and hold up to big block power the 57-64 Olds/Pontiac rear is really what people would expect to see if they went to the trouble to look, I sure would.
    There are a few shops doing them again, here is one of the better known ones.
    http://fabcraftmetalworks.com
    mad mikey likes this.
  27. DDDenny
    ^^^^^gospel^^^^^
  28. Schwanke Engines
    Schwanke Engines
    Please don't make another g***er abortion, 49-52 Chevy's belong in the weeds not jacked up at hick truck height. Why would you ever want to go to a worse suspension than a car had factory. Seems totally backwards to me. If you wanna do a drag car, do it right with independent front and back half the rear with a 4 link and 9" and let her rip.
    Sent from my XT1585 using The H.A.M.B. mobile app
    X38 and Special Ed like this.
  29. seb fontana
    seb fontana
    from ct
    My version
    mkebaird, OahuEli, chriseakin and 3 others like this.
  30. mad mikey
    mad mikey
    Period correct? Yes , if you can go with the olds rear, I love mine, and in your heavy car with big block, this is the rear you want.
