Technical Gauge ground burns up
Discussion in 'The Hokey Ass Message Board' started by desotoman53, Mar 11, 2020.
  1. desotoman53
    desotoman53
    from Conroe
    I hooked up my battery gauge and as soon as I hooked up the battery the ground burnt. It was ground under May Day the same place I have the ignition grounded.
  2. tb33anda3rd
    tb33anda3rd
    volt meter or amp gage?
  3. alchemy
    alchemy
    Is a “battery gauge” a voltmeter or an amp gauge? What’s a May Day?
    RICH B and Johnny Gee like this.
  4. squirrel
    probably an ammeter, connected as if it were a volt meter
    They work differently. An ammeter is a wire, if you connect it across + and - you will melt something. If you connect it in series with the main power wire that connects the battery to the rest of the system, it will work fine.
  5. desotoman53
    desotoman53
    from Conroe
    It’s the regular 1951 gauges. It was suppose to say under my dash.
  6. desotoman53
    desotoman53
    from Conroe
    Basically I hooked up the 1951 battery gauge the positive from my ignition and the negative grounded under my dash. As soon as I hooked up the battery it burnt the ground.
  7. Chappy444
    Chappy444
    Negative ground or positive ground?
    Chappy
  8. squirrel
    yup, exactly what I suspected. It is NOT a volt meter. you can't do that, it won't work.
    olscrounger and VANDENPLAS like this.
  9. desotoman53
    desotoman53
    from Conroe
  10. desotoman53
    desotoman53
    from Conroe
  11. BJR
    BJR
    An amp meter needs to be in series with everything else. A volt meter just needs to have a positive wire connected to one side of it and ground the other side of it.
    loudbang and stillrunners like this.
  12. alchemy
    alchemy
    Yep, squirrel is right, of course.
  13. BJR
    BJR
    What you have is an amp gauge.
  14. desotoman53
    desotoman53
    from Conroe
    Sorry I’m lost. I have the positive coming from my ignition wouldn’t that be a series?
  15. BJR
    BJR
    The positive from the battery or usually from the starter motor connection goes to the amp gauge, then to the ignition switch which powers everything else. That way the amp gauge reads all the current going through the system, except for what goes through the starter motor.
  16. desotoman53
    desotoman53
    from Conroe
    Sorry I’m just a jack***. My line from the starter goes into my fuse box then from there one of my ignition lines goes into my ignition. I got a new wire harness from easy wire and that’s the way it’s set up. I can run another ignition wire to my gauge instead of jumping it from my ignition or come from my gauge to my ignition.
  17. BJR
    BJR
  18. BJR
    BJR
    Cut the line from the starter and fuse box and put the amp gauge there. Make sure the amp gauge reads higher than the alternator output, or you will burn out the gauge if the alternator ever reaches full output.
  19. desotoman53
    desotoman53
    from Conroe
  20. desotoman53
    desotoman53
    from Conroe
    Thanks
  21. Ebbsspeed
    Ebbsspeed
    When you hooked up that ground the ammeter needle jumped real hard in one direction. That needle was centered right on the "0" when it came from the factory. Has it always leaned towards the +, or has that happened since you created a short through it?
  22. squirrel
    Electricity is mysterious. It's not surprising you don't know how this stuff works. Ammeters have not been used in cars for a long, long time. Don't knock yourself.
    You might want to consider not having a "battery" gauge at all. But if you do wire it, according to that neat drawing above, make sure you understand about wire size, current that the alternator can output, and safe wire routing, or the burned up wires could turn into a burned up car.
    Pist-n-Broke and pprather like this.
  23. pprather
    pprather
    The original generator on the 1951 was probably only able to put out 30 amps which if true would indicate you have a 30 amp gauge.
    What generator / alternator are you using now?
    Phil
  24. olscrounger
    olscrounger
    Squirrel and others nailed it. Maybe pull that gauge and send it to someone like Williamsons and have converted to Batt gauge (volt meter)
  25. stillrunners
    stillrunners
    from dallas
    good thread....think I'm learning something.....
  26. Corn Fed
    Corn Fed
    Is it adviseable to put a fuse (rated the same amps or slightly less as the gauge) between the battery and Amp gauge? Or maybe a fuseable link instead of a fuse?
  27. squirrel
    Usually fuses or fusible links are related to the size of the wire feeding the circuit. If you don't think the gauge will handle the current that the circuit carries, it's probably a good idea to not use that gauge.
    Pist-n-Broke, firstinsteele and BJR like this.
