Gauge, sending unit or wiring problem
Discussion in 'The Hokey Ass Message Board' started by BBrust, Sep 5, 2010.
  1. BBrust
    BBrust
    When my truck is started, my temp gauge goes directly to about 100 degrees and climbs to 240 within 3-4 minutes. I've checked the engine with a thermal thermometer and it reads about 165 degrees.
    I updated the truck during the last 3 years and prior to that the gauge and sending unit worked correctly. I'm also using the same wiring harness as before. To figure out the problem, I replaced the sending unit with a new one. Same problem. I then hooked up another temp gauge and it did the same thing.
    I was going to check the resistance in the sending unit wire but can't find my ohm meter. I'll pick one up tomorrow. Any idea what is wrong or what I may have done to cause this?
    A possible related issue is that the oil pressure gauge pegs to the right when the engine is started. Part of my update included a rebuilt engine that I bought in 1999 and has been sitting since then. It runs great and sounds good but the oil pressure concerns me.
    Thanks,
    Bob
  2. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Sounds like a bad ground, one gauge grounding into the other. Check dash grounds, engine to body grounds. Does the problem change when the dash lights are on?
  3. BBrust
    BBrust
    As I recall, I used a common ground for all of the dash gauges (back in 1998). I do have an engine to body ground along with a body to frame gound and a engine to frame ground. I turned on the lights and the temp gauge did not change. The oil pressure gauge moved about 1/32 of an inch to the left. Bob
  4. Antny
    Antny
    from Noo Yawk
    Mine did basically the same thing. Turned out to be a bad ground from the gauges to the body. Make sure the gauges have a proper and clean ground path.
