Gauge wiring problem/question
Discussion in 'The Hokey Ass Message Board' started by Tim, Jun 11, 2013.
  1. Tim
    Tim
    from KCMO
    Hey Guys,
    I'm at work so I didn't have time to trouble shoot this on the car so I thought id ask all of you instead.
    I have recently wired a gauge in my dash that is a 4 in one gauge. oil pressure, coolant temp, volts and fuel are measured and it lights up when you turn the headlights on.
    I got it all done and everything worked perfect until i came out this morning and went for a little drive. the gauges all seemed to be working correctly but as it was early i turned the head lights on and they all pegged out!? I shut the head lights off and they went back to were they should be.
    Also, the light in the gauge did not turn on when I turned the headlights on like it did previously/ like its supposed to.
    My thought is that a ground wire somewhere isn't grounding, like something loosened up from when it was working previously.
    Does that seem feasible to you all? It's something easy to check but don't have the time right this minute so figured id through it out there.
    its an Omega Kustom instruments 5" 4 n 1
  2. Sounds like the hot to the bulbs is shorted to the gage inputs or the ground for the gages.
  3. tfeverfred
    tfeverfred
    When you get home, trace your wires. Sounds like a short somewhere.
  4. tartruck
    tartruck
    I'd bet on a bad ground. The temp reading on my p/u jumped about 20-30 degrees when I ran with the headlights on. Pulled into the garage, killed the lights and she was running cool again. All because of a poor ground. Pulled a strong ground to the gauges and all is good now.
  5. 325w
    325w
    Easy to check out with a simple jumper wire. Clip on either end gage cluster to known ground. If that's doesn't fixit. Ground the headlites.
  6. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Bad ground is the case on most mystery issues like this.
  7. DoubleJ52
    DoubleJ52
    from Belton, MO
    You have a poor ground, most likely in the lighting circuit. Trying to find a ground through the gauges.
  8. 55 dude
    55 dude
    Easy check, run a ground wire direct to battery and hook that to your current ground and see if problem goes away, sounds like your chasing grounds.
  9. Tim
    Tim
    from KCMO
    looks like my ***umption was correct judging by your replies, I recall reading in the instructions that almost all problems that are called into there tech line are bad grounds.
    we'll find out tonight :)
    Thanks guys
  10. rfraze
    rfraze
    Original headlight switches had to be grounded to the dash OR a separate ground connection, because when you turned the switch all the way to dash light dim, the dome light came on. The switch sent ground (Only in that position) to the always hot dome light circuit, BUT only from ONE particular connection on the switch. After checking your grounds, make sure that the power for gauge lights comes from the proper pole on the headlight switch and that the switch is OK. Dash light power normally comes off the switch where the rheostat controls the voltage and bulb brightness. Twisting the knob to right usually increases the voltage at that connection, but only when the switch is pulled out or on. Hope this helps.
  11. 40FordGuy
    40FordGuy
    Ditto, grounds.....Give the lights a seperate ground,....from the instruments.
    4TTRUK
  12. Tim
    Tim
    from KCMO
    Problem resolved, lose ground as suspected
    Posted using My **** Tracey watch and the full custom HAMB app
  13. rfraze
    rfraze
    We appreciate the update. Enjoy the cruise.
  14. Tim
    Tim
    from KCMO
    Yeah I always try to post what the problem turned out to be on trouble shooting posts so it may help someone else.
    To be 100% honest I tightened up all the bolts to the grounds and after I had them all tight I noticed one of the ring terminals wasn't connected to a wire! Not sure how I didn't see that one haha.
    Bad ground as suspected
  15. Hey Tim!
    Send us a pic of your dash if you can. I've always wanted to see one of those 4in1 sets in a fattie. Thanks, Mike
  16. Tim
    Tim
    from KCMO
    Hmm I'm pretty sure there should be some photos in the last few pages of my build thread if you want to hunt that down... My desk tops of of commission a the moment let me try out this fancy new app and see if I can't put one here
  17. Tim
    Tim
    from KCMO
    Stolen from my wife's Instagram from our drive Saturday. Not the best of the gauge but you get the idea until you find them on the build thread
  18. 68vette
    68vette
    Thanks for posting the solution....you are the reason we try and help.
