Technical Gauge wiring question
Discussion in 'Traditional Hot Rods' started by DreamerJ, Feb 4, 2025.
  1. DreamerJ
    DreamerJ
    This one might be hard to troubleshoot from afar.
    simple 12 volt negative ground set up for my 31 Roadster. I am not running a ballast or a solenoid
    when I turn the key, the oil pressure gauge and water temperature gauges jump to the maximum reading. Everything else works fine incld interior lights, dash light, usb charger, fuel gauge and volt gauge. Any idea on why these two gauges immediately jump to the extreme? This occurs when I start the car and when I just turn the key to the accessory position.
    According to SW, they are wired correctly with brand new wiring. Entire car is brand newly wired.
    the gauges are new Stewart Warner. They worked previously.
  2. 19Fordy
    19Fordy
    Post photos and how you have them wired.
  3. Boneyard51
    Boneyard51
    Double check your wiring , usually both those gauges read by how much resistance to ground to get the reading. If your signal wire is shorted to ground it will do this. But it does seem odd that two gauges do it as they have seperate signal wires. But it is something to check and eliminate.
    Bones
    Johnny Gee and osage orange like this.
  4. Doublepumper
    Doublepumper
    from OR-WA, USA
    Perhaps the senders aren't grounded to the block, due to thread sealant insulating them.
    osage orange and TagMan like this.
  5. 325w
    325w
  6. DreamerJ
    DreamerJ
    Thanks for the responses. I'll check them again.
    osage orange likes this.
  7. DreamerJ
    DreamerJ
    Just checked. All gauges are grounded the same way to the block so it's not the G.
  8. '29 Gizmo
    '29 Gizmo
    from UK
    If you disconnect the wire at the sender do the still do the same thing
    osage orange, warbird1 and Boneyard51 like this.
  9. DreamerJ
    DreamerJ
    Update:
    1- bad oil sender
    2- bad wiring to temp senders.... aka got bad advice on how to wire them
    issues resolved
    thanks fearless hambers
  10. krgdowdall
    krgdowdall
    from Alberta
    I'm going through this right now.
    GM ignition Key has two terminals that switch to ground on START.
    One wire goes to the OIL Pressure sender. The other I am trying to trace its location, but also appears to goes to the gage cluster.
    You mentioned the gages worked previously, Has this problem just occurred or is this trouble shooting new wiring?
  11. DreamerJ
    DreamerJ
    It's a new problem ***ociated with swapping my Banger for a Flathead so while doing the engine swap, I rewired the whole car.
  12. 24riverview
    24riverview
    Normally the wires that go to ground on start are there to ground a warning light circuit, turns the light on while cranking so you know it's working.
  13. krgdowdall
    krgdowdall
    from Alberta
    Do the gages indicate properly with the engine running or remain at Max ? Sounds like a Gnd problem, Check that the block has a good ground.
    Gages should not be powered on Acc., only in Start/Run. Check Ignition/key switch or wiring.
    Running an Alternator or Generator ? Pos Or Neg ground ?
