Gauge with 5 inches glass showing, or more?
Discussion in 'The Hokey Ass Message Board' started by Mutt's37Buick, Aug 14, 2012.
  1. Mutt's37Buick
    Mutt's37Buick
    Does anyone know of a car or truck with a speedometer (or multi-gauge) with at least 5 inches diameter showing?
    This needs to be the gl*** that shows inside the bezel.
    If so could you tell me the year, make, and diameter of gl*** that shows.
    Thanks
  2. Magnum Wheel Man
    Magnum Wheel Man
    I'm making my own mechanical "monster" tach, using an early 60's Corvette tach...
    it's a match for the speedo, & measures right around 7"
  3. Mutt's37Buick
    Mutt's37Buick
    Is 7" the diameter of the gl*** that shows?
  4. Magnum Wheel Man
    Magnum Wheel Man
    thats the bezel size, this was a a dash mounted, & didn't have any gl***... I need to cut my own...
  5. Magnum Wheel Man
    Magnum Wheel Man
  6. Mutt's37Buick
    Mutt's37Buick
    Thanks for the info.
    Might me a possiblity, but may be too large. 5 to 5.5 inner diameter of the showing gl*** would be ideal.
    Your 38 Nash sure looks like my 37 Buick Roadmaster, but in much better shape.
  7. Magnum Wheel Man
    Magnum Wheel Man
  8. Big Nick
    Big Nick
    not sure of the exact measurement but try AD Chevy truck gauges. I havent measured my but I am almost sure they are 5"
  9. Magnum Wheel Man
    Magnum Wheel Man
  10. CutawayAl
    CutawayAl
    from MI
    At one time I had a speedo from a pre 1970 T-Bird. It was round. I don't remember what year, but I do remember it being in the size range you want.
  11. Mutt's37Buick
    Mutt's37Buick
    The aftermarket gauges that are called 5" actually have only 4.75 inches of gl*** showing. I need at least 5" gl*** because I have a modern speedometer that I want to hide in the dash and stick a round bezel in front of it for a vintage look. The speedometer I have is 5" diameter numbers at the outside of the numbers.
    AD trucks may be a possiblility. Can someone measure theirs for me?
    57 Chevy cars also may work.
    Thanks
  12. Magnum Wheel Man
    Magnum Wheel Man
  13. Magnum Wheel Man
    Magnum Wheel Man
  14. Magnum Wheel Man
    Magnum Wheel Man
  15. Mutt's37Buick
    Mutt's37Buick
    The 41 & 52 Roadmaster gauges were the first ones I tried.
    I'm trying to use Buick, then GM, then anything for parts.
    The 41 Raodmaster has a shown gl*** diam of 4.75.
    The 52 Roadmaster has a shown gl*** diam of 4.625
  16. Magnum Wheel Man
    Magnum Wheel Man
  17. GooGooMuck
    GooGooMuck
    from Tacoma, WA
  18. Magnum Wheel Man
    Magnum Wheel Man
  19. rottenleonard
    rottenleonard
  20. Mutt's37Buick
    Mutt's37Buick
    Good lead on a gl*** source, but I need the chrome or SS bezel too.
    Thanks
  21. oldolds
    oldolds
    Try a clock shop. I know they are hard to find, but they should be able to get you a bezel that you could use.
  22. hotrawd
    hotrawd
    from lima,ohio
    I have a speedo out of a mid-30's Dodge. It measures 5 3/4" and has a convex lens and chrome bezel. Would this work for you?
  23. Mutt's37Buick
    Mutt's37Buick
    It may work..
    Could you measure the outside diameter of the bezel for me.
  24. GooGooMuck
    GooGooMuck
    from Tacoma, WA
    If you need a bezel and gl*** that fits it, what about dissecting an old spotlight? Clear gl*** fitted to a nice round chrome bezel. That would keep folks guessing!
  25. Mutt's37Buick
    Mutt's37Buick
    Anyone with a jeep speedometer that could measure gl*** that shows?
  26. Magnum Wheel Man
    Magnum Wheel Man
    I'm suprised I didn't mention them... I have a CJ -5 sitting next to my other project... I could measure tonight if someone doesn't have the answer sooner...
  27. henry29
    henry29
    47-53 chevy trucks, the gl*** is exactly 5" the the bezel 5 1/8".
  28. Mutt's37Buick
    Mutt's37Buick
    Henry29, On AD
    So does 5 inches of gl*** show when the gl*** is installed in the bezel?
    Magnum Wheel Man,
    Thanks for all your suggestions. That would be great if you could measure CJ-5 Speedometer for gl*** that shows.
    Thanks everyone for all your suggestions.
  29. henry29
    henry29
    No, the gl*** itself is 5", I think about 1/16" of the gl*** is under the bezel on each side.
  30. Mutt's37Buick
    Mutt's37Buick
    henry28,
    Unfortunately the AD bezel would hide part of the numbers on the speedometer I'm using. I need the bezel to be slightly more that 5" inside dia.
    Thanks for your help.
