Technical Gauges
Discussion in 'The Hokey Ass Message Board' started by chessterd5, Mar 17, 2021.
  1. chessterd5
    chessterd5
    from u.s.a.
    Hello everyone,
    I have a stupid question cause I'm an idiot. Here goes. I welded a 1947 GMC truck dash into my 1927 model t ford. Before I installed it, I turned the dash upside down to make sure all the needles in the gauges moved through thier full range of motion. They do. So I said cool and welded it in. The idea being that I could hook it up later.
    Well it is almost time. My question is how do I know if they are 12 volt or 6 volt? Thanks.
  2. chessterd5
    chessterd5
    from u.s.a.
    Nope. No sir. Looks like plane Jane stock
  3. chessterd5
    chessterd5
    from u.s.a.
    And also thanks. I think I know what I need to do now.
    Do you install the voltage dropper in line to the main power wire to feed all the gauges?
    Tman likes this.
  4. Petejoe
    Petejoe
    from Zoar, Ohio
    One Runtz for each gauge.
  5. Or one of the Ford Type voltage reducer to supply all the gauges.
  6. chessterd5
    chessterd5
    from u.s.a.
    Ok. Thanks
    I have 4 gauges
    Oil is mechanical
    Amps which I don't know if l can or should hook it up on a more modern altanater.
    Fuel and water. So two runts should do it.
  7. Bob Lowry
    Bob Lowry
    Water gauge, if original, is mechanical. Hopefully the line was not cut. Amp/voltage gauge will
    work for 6 or 12 volts. You can buy an exact replacement for the gas gauge in 12v. Not a big
    deal. I have run the amp gauge with an alternator in my '54 3100 for 25yrs now. No problem. Keep in mind that the stock oil gauge only goes to 30lbs., the replacements
    can be had in 60 lbs. if you need a higher pressure gauge.
  8. Doublepumper
    Doublepumper
    from WA-OR, USA
    Providing your amp gauge is able to support the maximum current of the alternator, it should be fine.
